HID problems
Old Aug 13, 2005
rutscivic's Avatar
rutscivic is an unknown quantity at this point
HID problems
I just got a chance to hook up my HIDs today and im havein some problems. I hooked the right side up at first and it worked perfect. Then i left to get bulb grease and silicone at the advanced auto parts store right down the street. I came back and NOTHING It didnt work at all. I hooked up the stock headlight back up and it works fine. Is there somethign i should look for?? How could it work one minute and not the next? We tryed hookin the other HID up to the same side and neither of them work at all, but the stock headlights do. PLEASE HELP ASAP!
Old Aug 13, 2005
streetglower's Avatar
Moved to Mechanical Problems/Vehicle issues and Fix it forums
Old Aug 13, 2005
do you buy a cheap aftermarket kit? thats the problem. check your grounds and fuses, but you might have just blown the bulbs.
Old Aug 13, 2005
eye_see_you's Avatar
let the devil out
if your upgrading to HID you should change your fuses to atleast 25 amp from my kit anyway. first thing I bet is yoru fue blew
Old Aug 13, 2005
you should never upgrade a fuse with a higher amp rating. if something ever goes wrong, you risk buring up your wires and doing other damage.
If you install HID's, you usually want to install a relay. A relay is used to turn high current devices on and off.
Old Aug 13, 2005
yup my old kit actually came with relays already wired in.
Rogelio Rey
May 24, 2015 08:30 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Professional
Jan 6, 2002 08:27 PM
0100010
Jan 6, 2002 12:54 AM
