rattle when AC is on
Old Mar 17, 2002
ciViLiciOuS's Avatar
ciViLiciOuS is an unknown quantity at this point
just recently i noticed a rattling sound coming from the inside of the driver's side hood (closer to the front, drivers side fender) when i turn on my AC. but the rattling only occurs sometimes when the AC is off, but not as much as when the AC is on. what could it be?? im guessing wires that are vibrating off the firewall. im not to sure. any ideas??
Old Jun 11, 2004
xawcprez00's Avatar
xawcprez00 is an unknown quantity at this point
Civilicious- -
I've had the same problem, and come to the conclusion that it was the hood latch.
Check to see if yours is loose. I'm not sure how to tighten it (since it looks like they basically riveted it onto the frame), but ive stuck a couple sheets of paper folded up to take the slack out of it, and now it doesnt rattle anymore.
hope this helps
Old Jun 11, 2004
I was just gonna say that! There are rubber stoppers on each side that you can twist counterclockwise. It will make the hood sit higher and tighter. Just don't do too much or the hood won't match with the body (will be raised too much when closed).
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
