Help!!!... Some Oil Stains on Floor..
Old Mar 20, 2002
gqsang's Avatar
gqsang is an unknown quantity at this point
I left my 2k1 civic 3000miles... in the garage last night... and I find some oil marks... on the floor...
not alot but.. some..
I've put some newspapers on the floor to verify it.. it's not alot.. but gets me worried..
is this suppose to happen to a new car?
Let me hear your thought.. what could it be?
Old Mar 20, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
not supposed to happen. it could be anything....
Old Mar 20, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
should be a warranty issue. have you gotten an oil change yet? (youre not supposed to until 5000 miles) if you did, and the washer (cant remember what its called) wasnt replaced, that could be whats causing the leak. places like jiffy lube probably wont replace the washer unless you give them a replacement to put in ($0.25 from the dealer)
Old Mar 21, 2002
HONCIV2K1's Avatar
HONCIV2K1 is an unknown quantity at this point
You can get the washers, last time I checked, from HPARTS..COM for 10 cents a piece...just an FYI.
Old Mar 22, 2002
02Si's Avatar
02Si is an unknown quantity at this point
To clean the oil spots on your carpets, first take them out and dust it off. Then use some liquid detergent, dishwashing soap will do. Dillute it a bit and treat the spot, work it in with a small brush, like a toothbrush. Wet the entire carpet and keep it wet by putting the entire carpet in a trash bag for one day. The next day, rinse it out, then let it air dry one or two days.
Old Mar 22, 2002
02Si's Avatar
Well, just reread your thread, on the floor, treat the floor then. Best of luck!
Old Mar 25, 2002
Diznavis's Avatar
02si, hes more worried about the oil leaking than about there being oil on the floor
HONCIV2K1, thats good to know, i should probably order some since im getting close to my first oil change (got around 4400 miles now)
Old Mar 26, 2002
02Si's Avatar
Are you sure them oil stains and not something else, yak yak yak[IMG]i/expressions/laugh2.gif[/IMG]!
Old Jun 27, 2002
astr033's Avatar
astr033 is an unknown quantity at this point
I got an oil change at the local dealership about a month ago and since then I've noticed a tiny oil stain under where I park my car keep growing and growing, a little bit each day. I finally took it back to the dealership today and they said that they'd have to keep it all day and I'd have to bring it back tomorrow if they didn't get the part in that they needed. I'm not sure what the matter is just yet. I thought it would be a simple problem. I figure whatever it is, it should be covered by the warranty. Right?
Old Jun 27, 2002
2cute's Avatar
2cute is an unknown quantity at this point
There was a service bullitin a while ago about a leaky seal that was causing an oil leak. May wanna search see of you can find it. Either way it is a warrenty issue take it in and have it looked at.
Old Jun 27, 2002
astr033's Avatar
Thanks 2cute. I'll check out the TSB's.
EDIT: Here's a link to a search for technical service bulletins: http://www.nhtsa.dot.gov/cars/problems/tsb/
Old Jun 27, 2002
astr033's Avatar
Defective crank seal is what the service guy told me.
Old Jun 28, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Humm yeah I have been noticeing some marks on my floor for mths now. Maybe thats what it is, humm because the dealer is the only one who has done my oil change
Nick
alaga
25
Aug 13, 2015 04:42 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
ZILLA
Jul 13, 2015 04:52 AM
ZILLA
Jul 10, 2015 06:05 AM
ZILLA
Jul 5, 2015 05:24 PM
