rear axles sqeaks when hittin small bumps
Old May 27, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
Question rear axles sqeaks when hittin small bumps
everytime i hit a little bump or uneasy surface, it squeaks. it sounds like its coming from the springs. any1 have this related problem? should i be concerned with this issue? it jus started since this past week. Thanks for your comments and inputs!!
Old May 27, 2003
Mbow's Avatar
It's probably the struts. The oem struts are known to blow but the honda dealer tells me that they get lots of civics with struts that squeak. If you have the factory suspension, I would take it to the dealer.
Old May 30, 2003
JSpurgeon21's Avatar
JSpurgeon21 is an unknown quantity at this point
wow, i was just about to post the same topic. yesterday, for the first time, my back end started squeakin pretty bad. have you taken it in yet?
Old May 30, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
It's very easy to see if your back struts are blown. Just look under the car from the rear and look at the shocks. If they look dry, then they are not blown. You can also use your hand to feel around the shock... if there's no liquid, you're ok.
I don't have a squeak sound, but I have a metallic groaning sound coming from the rear middle part of the car whenever I make a slow left turn, and my struts are fine. Probably just needs some lubing somewhere.
Oh well, part of the aging process I suppose (slightly over 2 years now).
Old May 30, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
dude, my car creeps like a haunted house whenever i go up driveways.
Old May 30, 2003
Ronin's Avatar
My moonroof also creaks when I enter driveways.
Old May 31, 2003
hahaha. i had to laugh cuz it wasnt the rear axles. it was the rear deck. it was loose from when i had put in new speakers. its fine now. mah bad guys!
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
OptimisticWay
Jul 10, 2015 04:31 PM
silentz
Jul 9, 2015 08:16 PM
BootyDo
Jul 7, 2015 06:06 AM
