Water Leak Under Corner of the Dash on Drivers side
Old Jun 4, 2003
jodeny's Avatar
jodeny is an unknown quantity at this point
Hey fellas,
I have a Water Leak Under Corner of the Dash on the drivers side. As a result the front and back drivers side carpet is soaked!!!!!!!!! I know this was a problem on the 6th gen.......does anyone have any info on this? Either on the 6th or 7th gen? Can you lead me to a site that can help. Any suggestions or shared experiences are appreciated.
Thanks,
John
Old Jun 4, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Re: Water Leak Under Corner of the Dash on Drivers side
Originally posted by jodeny
Hey fellas,
Thanks,
John
Maybe it's related to this?
Old Jun 4, 2003
rino's Avatar
rino is an unknown quantity at this point
mine does that too, any info is appreciated
Old Jun 6, 2003
jodeny's Avatar
>>Bump>> anyhone out there??
Old Jun 6, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i'd take it to honda
Old Jun 6, 2003
solar's Avatar
solar is an unknown quantity at this point
Could be 2 things
1. Does it only happen when you have the A/C on? If so your evaporator coil drain is most likelt clogged. It could be clogged by leaves or bugs or just dirt. Take it to a shop and have them clear it out.
2. If it leaks all the time without the A/C on your heater core might be leaking, you should know this easily because it will smell like coolant/antifreeze and your radiator will be low and you might overheat.
If the water is clear with no smell I'd bet on the evaporator drain is plugged up.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
Supramk3
May 11, 2015 07:55 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
