common probs to fix before end of warranty?
Old May 23, 2003
Naito's Avatar
Naito is an unknown quantity at this point
I've been reading about some of you ppl having trouble with the rear drum brakes. How do I tell?
I want to get all the outstanding probs out of the way and repaired under warranty before it runs out (probably by end of next month).
There's probably some stuff that I've simply accepted as being normal now when Honda should be fixing it for me.
so far repaired/replaced on my car under warranty:
radio
rear suspension (various parts)
front struts
instrument cluster
anything else I should be paying particular attention to?
Old May 23, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You can't just walk in and have things replaced because other people have had problems. You need to have the problems in your car before they'll do anything.
Does your seat rock?
Does your Clutch Squeek?
Does your engine severely vibrate?
Other than that, it seems you've had the stuff replaced.
They're not going to replace the brakes on warranty anyway, its a wear item.
Old May 23, 2003
Naito's Avatar
oh I know, I have to complain to them about it and they have to actually see that there's a problem before they replace it. But want to see if there are things I should be paying attention to that I maybe have been taking for granted as normal now that I've had the car for almost 3 years, and if they aren't normal I want them replaced/fixed before warranty ends.
Old May 23, 2003
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Whats wrong with your radio?
Old May 23, 2003
Naito's Avatar
had it replaced because it kept resetting and asking for the security code.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
RyanCoult
May 29, 2015 09:50 PM
Ma213802
May 18, 2015 07:01 AM
chuffsy
May 15, 2015 12:50 PM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
