Sorta rough idle when first started in morning
Old Jun 11, 2003
flotsamm's Avatar
Anyone else have this problem?
When I first start up my car from sitting overnight, the idle is kinda rough and it stumbles here and there. Now I know that its suppose to idle higher since its cold, but the stumbling make me a little worried. When it does stumble, its not like its gonna stall out or anything but you can feel it jerk.
After it reaches operating temp, it idles fine. But I'm still curious if others have this sorta problem also.. thanks.
Old Jun 11, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
idle in wat range?
Old Jun 11, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
yeah, my car has been idling pretty rough since i passed the 28,000 mile mark....
Old Jun 11, 2003
malice29r's Avatar
malice29r is an unknown quantity at this point
Mine idles kinda rough too.. the car kinda shakes a bit, i can notice it in the mirrors..
But I have noticed that every time that it "shakes", the rpms drop a bit.. so I think it's just caused by the ECU lowering the rpms as the engine warms up...
(btw i'm not too knowlegable with cars, so I just assume the ECU controls the idle speed )
Old Jun 11, 2003
flotsamm's Avatar
So I guess I'm not the only one then.. not very encouraging at the moment.. grr.
Malice29r- I agree, sounds like the TPS adjusting from the ECU is telling it to do But damn.. I was kinda hoping it would be a smoother drop..
iluvbritney- its about 1100 rpms at first, then slowly drops(like it should) as it gets warmer. At full operating temp, I sit at ~750 rpms.
Old Jun 11, 2003
jedi's Avatar
jedi is an unknown quantity at this point
Hi flotsamm,
How many miles on your car ?
It could be a fouled plug.
IMO -- No matter how well they make spark-plugs
I don`t think they`ll last as long as they say.
Just a thought. Also how about your gas?
I run 91oct , even though the book and others say
that I don`t have to , just fell better running better gas.
jedi
Old Jun 11, 2003
ak's Avatar
ak
Retired Mod
I'm running denso iridium ik20 and still get that rough shaking... i thought it was the oil at first, but that was incorrect.
Old Jun 12, 2003
flotsamm's Avatar
Originally posted by jedi
Hi flotsamm,
jedi
Hi,
I have just over 9000 miles on my '02 coupe... plugs are most likely fine. Once its warmed up, it idles fine. So I think it might just be the TPS(throttle position sensor) adjusting the idle, but in a rough way. Not sure if 91 octane would help me, though I guess its worth a try. I run Chevron mid-grade 89 octane right now.
Old Jun 12, 2003
jedi's Avatar
Hi flotsamm,
9K, It sounds like the plugs should be A-OK !
If you drive in alot of traffic maybe your injectors
are cloged.
My 03 Civic doesn`t have enough miles on it to be
any real help, But my old Honda Accord would run ruff
if I did too much city driving. What I used to do is just
take it on the highway and run it for a while in 3rd (auto trany)
most of the time that worked. I didn`t red-line but around
4K and just drive for a few miles should be enough is see
if it works.
I`m sure it`s nothing too major could be as
simple as slight carbon build-up to a bad batch of gas.
If it doesn`t clear up I would take it back it the dealer.
I`m not a big fan of dealerships , but sometimes you
have to. Best of luck
jedi
Old Jun 12, 2003
flotsamm's Avatar
Thanks Jedi, good thinking! But unfortunately its a daily driver that see's maybe 2 miles a day of stop and go. The rest is a 60 mile round trip commute.. thanks again though, appreciate your input.
Old Jun 12, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Nah, I think it's fine. I was worried about that too, and now I'm almost at 30K miles and it still idles roughly when I start it. Trust me, I look at my engine and the thing looks like it's just gonna explode on me. But after a while, it idles fine and runs great.
Old Dec 29, 2003
Zigen1's Avatar
Zigen1 is an unknown quantity at this point
same problem here. It idle rough during the first 10 mintes of driving.
Old Dec 29, 2003
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
ya sometimes when I start up my car in the morning and it seems to be idling roughly but after letting it sit for a little while it seems to go away after the engine has warmed up enough. I think it might be just a weather/temperature factor because when i start it up during the summer I dont notice as much rough shaking or vibrations.
jbradley4809
Apr 7, 2017 04:23 AM
crowtoo
May 11, 2015 06:50 PM
Ashley Farr
May 7, 2015 05:01 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
black2k1vtec
Dec 6, 2001 09:49 PM
