SRS Light
Old May 21, 2003
MadSpeed's Avatar
MadSpeed is an unknown quantity at this point
SRS Light
Does anyone know how to cut off the SRS Light in the dash.....mine has been bugging me for over 6 months and i'm tired of it.
Old May 21, 2003
AdamOSU's Avatar
AdamOSU is an unknown quantity at this point
You probably want to get that checked out, because with that light on your airbags might not deploy or your seatbelts might not lock up in an accident. There's a diy to reset the light if everything is ok in your srs system. If something is wrong, you wont be able to reset it. You will need to take it to the dealer.
Reset SRS DIY
I went to my dealer and they only charged me 20 bucks to reset it, but if you can do it yourself you can save a little money.
Old May 21, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
They reset mine twice... then with the last inspection they found that a sensor (passenger) needs to be replaced. They replaced the sensor.... the next day the light came on again. I took it back and the sensor (driver) needs to be replaced. This time they had to order the part.
So get it checked out before you reset it yourself... it may not be a false alarm.
Old May 22, 2003
Weaponx12o's Avatar
yea go to the dealer. you wouldn't want that thing malfunctioning on you when you need it
Old May 22, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
Imagine driving 75 on the highway and your airbags go off because a bad sensor because you didn't want to go get it looked at by honda for $20.00 wouldn't you just feel stupid telling the Highway Patrol what happened...
Old May 22, 2003
nitehawk's Avatar
If you have installed aftermarket seats this is a common problem, but other than that I wouldnt really know.
I would suggest getting it looked at
Old May 23, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
just do the $hit yourself.. it takes me less then a minute to reset mine with a paperclip each time.... if you know what set it off then do it yourslef... but if your not sure take it to the dealership and if your car is under warenty they have to reset it with out charging you for it.
Old May 25, 2003
Voiceofid's Avatar
End Bringer
the local dealership wanted to charge me 85 dolalrs, just to turb the light off, and i know it's perfectally fine, because all i did was i turn the car on with the pass seat disconnected
Old May 30, 2003
JSpurgeon21's Avatar
JSpurgeon21 is an unknown quantity at this point
i am going through the same problem except i know i triggered it. i was putting white gauges in and also took apart my stereo and junk in the dash. hope i didn't screw anything over.
Old May 30, 2003
armageddon's Avatar
armageddon is an unknown quantity at this point
If you got a warranty its free. Just get it looked at. I did it a month ago
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
