40k mile maintenance
Old Jun 30, 2003
Master's Avatar
Banned by Admin
What is the maintenance on the 40k mile check up? anyone know?
Old Jun 30, 2003
Master's Avatar
Banned by Admin
Well I just talked to my dealership and they said the only thing for the 40k service is an oil change. Is this correct?
Old Jun 30, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
According to the list my Honda dealership gave me, 40K maintence is just an oil change and new oil filter, plus checking and topping off all fluid levels. It's just your typical oil change.
30K was the big one that included alot more stuff.
Old Jun 30, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
Whats involved in the 30K check up?
Old Jul 2, 2003
Master's Avatar
Banned by Admin
search it has been talked about the last 3 days. Either this forum or the tech forum. All I know is that you are going to be paying somewhere around $300 for the 30k maintenance.
Old Jul 2, 2003
flotsamm's Avatar
This is according to what Honda's Owners Link.. you should try it. Go to Honda.com and click on the Owner's Link page.
30K Miles:
Services to be performed:
Replace air cleaner element every 30,000 mi/48,000 km (independent of time).
Replace engine oil.
Rotate tires.
Inspect and adjust drive belts.
Replace dust and pollen filter. (See Dust and Pollen Filter on page 235 of your owner's manual for replacement information under special driving conditions.)
40K Miles:
Replace engine oil.
Rotate tires.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie-rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
= See information on maintenance and emissions warranty, last column, page 199 in your owner's manual.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
MajTom
Jun 2, 2015 11:48 AM
mrohitredd
May 28, 2015 10:03 AM
bsmiley
Apr 27, 2015 01:27 PM
