power steering fluid leaking !
Old May 30, 2003
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
i just realized that my power steering fluid is leaking !.. i'm not sure if it's because of the aftermarket accessory pulleys or if there's a leak in the tubing .. but does anyone know what happens when i run out of fluid ?.. do i damage anything ?.
your educated responses will help me
Old May 30, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
I think it will damage the pump because the fluid is like...lubrication.
or someone educate me too, is the fluid only used to create pressure?
Old May 30, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
You might have a blown hose. Get it repaired immediately. The hose is the cheapest to replace. Let's hope is not the pump.
Old May 30, 2003
flotsamm's Avatar
When you run out of fluid it'll be harder to steer and you might burn up your pump. I doubt the after-market pullies caused the leak unless a hose was damaged when installing them. I would get it fixed ASAP. If the hose breaks while your driving, you could end up with a pretty big mess inside the engine compartment and potentially cause an accident if your not ready when you lose power steering. BTW, some peeps completely remove power steering to gain some power back and/or get a better feel for the road...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
bsmiley
Apr 27, 2015 01:27 PM
