Clunk Sound when Braking is normal?!
Old Feb 16, 2004
kenji4861's Avatar
kenji4861 is an unknown quantity at this point
So each time I go reverse and then go forward.. and when I press on brake... it makes this huge "CLUNK" sound.
I told Honda about it and they told me it was normal. Anyone have any experience with this?
Old Feb 16, 2004
FurBall's Avatar
FurBall is an unknown quantity at this point
Re: Clunk Sound when Braking is normal?!
Yes and no...
I dunno about you guys, but my 2001 Acura EL has 4 disc brakes all around... It ended up being my rear disc pads being LOOSE. Nothing you can do, it'll go away eventually...
I asked at the dealer... They said they COULD put in some shims, but then your pads would wear out like 4 times as fast. Not sure WHY it happens, it just happens. I don't get it any more.
It sounds like as if the entire caliper is loose when you brake I know the feeling
Old Feb 16, 2004
tfnaaf's Avatar
BLDNPSI Mod
Normal? NO! Could be a variety of things from loose brake pads, caliper, suspension bolts to engine mounts
Old Feb 16, 2004
tfnaaf's Avatar
BLDNPSI Mod
Re: Re: Clunk Sound when Braking is normal?!
Originally posted by FurBall
Yes and no...
Sounds like your dealer is feeding you a line of crap.
Old Feb 17, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
I had that problem i just replaced the pads with some aftermarket ones. Do a search you should find some answers.
Old Feb 17, 2004
PunkingCivic's Avatar
I need TP for my bunghole
it is normal there is just a little space in caliper allowing the brake pads to move.
I had the same issue and when I had the brakes serviced it went away.
Old Feb 17, 2004
Diablo's Avatar
it goes away but after 10,00 miles or so it comes back.
Old Feb 18, 2004
Da1lyDr1ver's Avatar
its normal, the oem pads are cheap so if you replace your pads with aftermarket ones it'll go away. it has something to do with the clips they use on their pads.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
TiggerDX
Jun 18, 2015 01:43 PM
opticalvetc
Jan 1, 2002 08:32 PM
civicdude
Brakes
Nov 21, 2001 08:00 PM
