How many miles from OEM Pads?
Hi everyone,
just curious in knowing how many miles your oem pads lasted. I had to replace mine at 14000 miles.
Is this normal considering that i don't usually race my car?
Oh don't forget to post your pads mileage.
Thanks.
Is this normal considering that i don't usually race my car?Oh don't forget to post your pads mileage.
Thanks.
much depends on how you drive - if you brake harder or tend to ride the brake pedal..they will wear quicker.
I have a 2k1 coupe with original pads - 25k miles and also a 98 sedan, original pads replaced at just over 50k miles.
Autocross Junky
65,000, before I switched to my Porterfields (for specific reasons) I could have gotten anoher 10 out of the pads and 30 out of the shoes, easily. Of course I do a lot of Freeway driving.
I replaced mine at 24,000. granted they had a little bit of life left...
Did you actually get to see the old pads, or did someone just say you needed new brakes?
Cause unless you drive the **** out of your car, they should last you minimum of 50,000 miles.
http://www.7thgencivic.com/forums/sh...62#post1866062
go there to see the status of my brakes after 24,000 miles of fairly hard driving.
Originally posted by bullseye
My originals are still on the car at 90,000+ miles - lot of highway miles!
I checked my brakes at 30K miles. The front pads looked like I could go at least another 20K. I took my rear drums off also, and the shoes had minor wear. I think I can get at least 80K from the rear shoes.
I don't really think I'm a wuss with the brakes either. I drive mostly highways, but with a lot of stop and go traffic. I try not to stomp on them really hard since it it heats up the pads and rotors too much, but I consider myself a mostly average driver, but drive aggressively at times.
Some advice- I don't wash my car unless I know the brakes have cooled off. Spraying water on hot rotors can cause warping.
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
edgenet
Apr 28, 2015 07:49 PM
