8th Gen 2006 - 2011.
Comlpete a rear break pad replacement
Old Apr 27, 2015
edgenet's Avatar
edgenet should not be trustededgenet should not be trusted
Installed new rear break pads on a 2009 LX-S and now for some reason my e-break I have to pull all the way up almost to max to engage vs only a few inches before I replaced the pads. Is there an adjustment I missed or ?????
Old Apr 27, 2015
Re: Comlpete a rear break pad replacement
What method did you use to make the pistons retract?
How did you align the "cross" in the pistons prior to installation? (position, not method)
Old Apr 28, 2015
edgenet's Avatar
I just turned the piston inward wit a large screwdriver. I then installed the pads and the was it. I did noticed 3 pins on the pads thought nothing more. Was I supposed to align the pins to the slots on the pads ????
Old Apr 28, 2015
Absolutely! You looked at it and saw it, now think!!! You can probably look through the big hole on the outside of the caliper and see how the piston is pushing on the pin instead of being flat/flush against the back of the brake pad.
If you don't align the slot with the pin, then the piston will push on the pin at the top-center of the brake pad and cause the pad to wear at an ugly angle. And it can wear the rotor at an ugly angle as well if you leave it that way too long.
HTH
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MamaBear2015
May 3, 2015 02:17 PM
leon1
Apr 28, 2015 07:32 PM
thesushiboy
Apr 12, 2015 02:54 AM
supercivic01
South
Nov 30, 2001 11:27 AM
