S mode on CVT<<<
Old Apr 14, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
S mode on CVT<<<
So, I gather that if you take off in S mode, its first gear and climbs all the way to redline without shifting? and where is the S mode setting at? My options are P-R-N-D-D3-2
so wheeres S mode?
Because if im in drive and take off, once it hits second gear it bogs back to 4000 rmps the streadily climbs. This s mode eliminates this?
I only see S mode on HX, not EX?
Old Apr 14, 2004
dml5551's Avatar
dml5551 is an unknown quantity at this point
P-R-N-D-S-L (HX) CVT TRANNY
Old Apr 23, 2004
CK's Avatar
CK
CK is an unknown quantity at this point
In S(sport) mode, gears will change at higher rpm, about 500 rpm more than normal mode. The rpm will still drop after each gear change. It's not eliminated. There's no S-mode in the Civic.
You can manually do the S mode with P-R-D-D3-2 set-up by 'holding on' to the gears.
Floor it in D3. Once the rpm needle touches the redline, the box will automatically change to D2. Once in D2, pull the stick back to 2. Now you can hold on to 2nd gear pass redline to seven, seven-five. Then push the stick forward to D3. RPM will drop and gear 3 is engaged. Rev the engine to 7.5 when you again push the stick forward to D.
Summary, D3>2>D3>D
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
Luluharp
Sep 27, 2015 11:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bikergofast
Sep 12, 2015 10:54 AM
