Clicking Noise When I Back Up
Old Mar 10, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
MY CAR WHEN I BACK UP MAKES A POPPING NOISE BUT THERE IS NO TSB FOR IF THAT I SAW......
ITS NOT THE SUSPINSION (SPELLING) BECAUSE IT HAPPENS WHEN I BACK START UP AND WHEN I APPLY SOME BRAKE!
HELP!
THANK YOU!
Old Mar 11, 2004
Da1lyDr1ver's Avatar
does it just pop once or does it keep doin it? then, when you go forward again and apply the brakes after backing up, does it pop again? if so then its just your brake pads shifting so its no problem.
Old Mar 11, 2004
AutoK20A3's Avatar
AutoK20A3 is an unknown quantity at this point
Yeah he's right. It's normal. My old 2003 Vic did that.
Old Mar 11, 2004
draganjr's Avatar
Cool, thank you!
i had a feeling it was the brakes but had to make sure, thanks again.
Old Mar 11, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
yeah i have the same nosie but only after someone hit me and did 4000 in damage--accidents suck--
Old Mar 16, 2004
EŽik's Avatar
Well to play it safe I would bring it in... if it's a clicking noise (I had that happen to me) then it's more than likely your CV boot (don't ask me, thats what honda said) they needed to replace that and a cracked rod of some sorts. Wouldn't hurt to bring it in if your still on warranty.
If it's a popping noise, the break pads do move forward and back, that is normal, and they usually make a popping noise when you either break, stop breaking, or take the handbreak off.
hope this helps
Supramk3
May 11, 2015 07:55 PM
civicns
May 8, 2015 09:49 PM
Dorval Andre
May 1, 2015 09:37 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Sparty
Nov 15, 2001 04:55 PM
