TPS Problem
Old Mar 27, 2004
nittanylion504's Avatar
nittanylion504 is an unknown quantity at this point
Question TPS Problem
My car is throwing a code that says my TPS voltage is too low and another manufactureer specfic code (I forget what it means). Here are my codes if anyone has a reference chart: P0122 and P1298. I'm assuming the TPS is going bad because of the low voltage, and perhaps the manuf. code is a result of that. I looked at the TPS and it seems like its integrated in the the throttle body. Is this correct? If so, does anyone know where I can get a Honda TB for a decent price? I'm assuming the dealer part is really expensive and I'm not that interested in performance parts if they are a much bigger cost. Any suggestions/advice?
Old Apr 4, 2004
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
Hey i had the same problem with the TPS for months and i was looking for a throttle body frantically cause its incorporated into it. But what i did was a member on this site was selling his TB on ebay and i won it replaced it and now the TPS works...As for getting it somewhere else it could cost close to $200 new, but if u have good luck u might find a used one in a junkyard
Old Apr 5, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
From my Helm's manual:
P0122: IAT Sensor Circuit Low Voltage
It gives some instructions on what to do based on tests that you have to perform with an IAT "scan tool" (I dunno... that's what the book says), and most of the test recommendations end up being replacement of the IAT sensor. (IAT = intake air temperature)
P1298: Electrical Load Detector (ELD) Circuit High Voltage
Gives some instructions on what to do ... seems to be related to fuse no. 4 ACG (10A).
If you need these pages from the manual, I don't have a scanner, but you can pm me and we can try some other way to get this info to you.
Old Apr 6, 2004
Thanks, I guess I looked up the wrong code and thought it was the TPS. I can't see the IAT being very expensive. Its only about 15 bucks for my GM. Do you know of any scanware that I can get for my civic...analagous to datamaster if you are familiar with that. Thanks again.
Old Apr 7, 2004
Ronin's Avatar
Sorry, don't know anything about scanware or datamaster. Go to your dealer's parts department and ask them if they know.
Old Apr 7, 2004
MegaHurtz's Avatar
Hmmm... did you finish your TPS reports?
Chris71087
Jun 9, 2015 11:59 PM
Flipg123
May 8, 2015 01:15 PM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
