Vibrating Problem
Old Mar 12, 2004
rkotlowski's Avatar
rkotlowski is an unknown quantity at this point
Vibrating Problem
People,
I have a problem. My steering wheel vibrates when I am on the high way doing 110Km (60m/h approx.)
It does not happen at slow speeds or if I break. I do have rims (17's) with no Hub Centrics...would this be the problem?
I had my rims on last year and I don't remember the stering wheel vibrating this much?
Thanks in advance,
Rob
Old Mar 12, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
This has been discussed many times before. Your problem can be any of the following:
1) Out of balance wheels/tires : get them re-balanced.
2) Your aftermarket alloys need hub centric rings in order for them to mount properly onto the car.
3) One or both of your front rims are bent (hit any curbs recently?)
Based on the speed your vibrations starts, I betting that it's a simple case of problem no. 1.
Old Mar 12, 2004
rkotlowski's Avatar
Thanks...Any other ideas?
I did not hit any curbs lately, That I am aware of...
Rob
Old Mar 13, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
pull them all off and have them rebalanced.....that is your problem....i wouldnt worry about anything else
Old Mar 13, 2004
You need to get an ALIGNMENT done, not balance. Mine also vibrates over 65mph and I have stock rims. Over time the alignment will be off and cause the vibration. It also reduces gas mileage.
Old Mar 14, 2004
Ronin's Avatar
^^^ I don't think so .
If your steering wheel shakes at highway speeds, I can almost guarantee it is NOT caused by mis-alignment.
Old Mar 14, 2004
flotsamm's Avatar
Rotate the front tires to the rear on the same side and test drive. If the vibration goes away or is felt in the rear now, its a balance issue.
Old Mar 14, 2004
Well, my last car did this and getting an alignment fixed the problem. I guess unevenly worn tires would also vibrate.
Old Mar 14, 2004
Rufus's Avatar
Silly Canadians
Old Mar 14, 2004
rkotlowski's Avatar
Originally posted by Rufus
Silly Canadians
??? - I will just leave this comment alone!
I had a wheel balance done it seemed to take away most of the problem. There is a little vibration in the steering wheel still. You can hardly notice it. I guess I am very **** about my car. LOL
Thanks again for the help.
Rob
Old Apr 28, 2004
bxjay320's Avatar
bxjay320 is an unknown quantity at this point
I have done everything that was mentioned above, and
I still get vibration in my steering wheel.
I am soooo lost?????
I love my rims, but i might have to sell them.........
Any help!!!!!!
Old Apr 28, 2004
Update: Now my old tires made the car vibrate over 55mph with the stock 15 inch rims. I just got my new tires on and balanced (alignment tomorrow), and the vibration is gone. The old tires were just balanced recently when I got stock alloy rims put on. So I don't think balancing is the problem, or alignment. Maybe it's your old tires that have uneven wear or other problems.
Old Apr 29, 2004
tombgoodu's Avatar
tombgoodu is an unknown quantity at this point
I have the OEM firestone on my car, in the morning on the highway I get the same virbration at 110 k/h a short period of time, I think it's a flat spot from overnight cold here in Toronto. After the tires heat up it goes away.
Old Apr 29, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Unless you have a flat spot or jacked up a rim (which you would know about)
it is one of two things
1. a tire through a weight
2. the front end is out of elignment.
Go to a shop and pay about 40 US dollars and have it done.
they will balance and elign and all will be well.
Old Apr 29, 2004
Ronin's Avatar
If you have wheel locks, take them off and put stock nuts back on, and see if that helps any. That was what happened to me.
Old Apr 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
Just to clear something up. Its IMPOSSIBLE for an alignment to cause the car to vibrate. The alignment being out can cause tire wear. Bad tire wear can cause vibration. But there is no way possible for an alignment to directly cause a vibration. Vibrations are caused from out of balanced rotaing masses. Doing an alignmnet only changes angles of your suspension it doenst change rotating mass in any shape or form.
Old May 9, 2004
DxKid_03's Avatar
DxKid_03 is an unknown quantity at this point
If you had it balanced and still have the problem than it may be a broken belt in your tire.. if it is a broken belt than there maybe a road hazard warrenty on your tire.. I have seen this alot.. look at the tread wear.. if it is up and down, then more than likly it is a broken belt.
Old May 9, 2004
DxKid_03's Avatar
and as well, from my experience in automotive, alignment will not cause vibration, it will cause ur tires to wear either on the inside or the outside.
Old May 11, 2004
tombgoodu's Avatar
If the rims you have are like my, you need to static balance for rims. Some garages use the normal weights that show from the out side and what some garages do is use the same weights, but install them to the inner rim to counter act the balance from the factory giving you balance. Get your balance done by static balance, it cost more the weights are self adhesive, installed by the flat inner surface.
Old May 12, 2004
civic12's Avatar
civic12 is an unknown quantity at this point
i had same problem....nothin would fix it..i tried everything....ended up taking it to honda and they told me i had to have new rotors.....i got them under warranty and while i was at it i went ahead and got new brakes....cleared it all up.....but they told me it was my rotors...
Old May 29, 2004
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
Yes this is the problem. It is the stock rotors, they overheat and cause this problem. After many times of powerful braking and over heating they will warp and or they can happen when they get wet when they are extremely hot. So just go and get brembo rotors or after market rotors that are better and can withstand the overheating.
conspiracy90
Jun 7, 2023 01:01 PM
mrohitredd
18
May 14, 2015 07:35 PM
jakeconnor
May 5, 2015 07:30 AM
streetglower123
Apr 12, 2015 10:56 AM
bambuski
Dec 27, 2001 09:38 AM
