help with a squeak noise from the engine?
Old May 7, 2004
DarkCivic2k2's Avatar
DarkCivic2k2 is an unknown quantity at this point
I have a 2002 Civic EX and when i rev it up to about 5 or more RPM and release the gas pedal it makes a squeaky noise coming from the engine. I have 11K miles on it and have not had any other problems. I heard it might have to do with the belts slipping but, i dont know. Did anyone else have these problems with there civic or does anyone know how to fix this. It sounds like a Dog's squeak toy.
Old May 7, 2004
My car is an automatic, by the way.
Old May 7, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
easy solution. Remove each belt and listen for the squeak. But do not run the engine for more than 1 min. Based on your description, most likely your right.
Old May 7, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
it's the bolt with spring between the exhaust header and the downpipe...
I have this problem for about a month now, I got an aftermarket Hi Flow Cat and the spring's loose that causes the sqeaking...
If that's not where the noise' coming from, then 99% sure the belt is the problem...
Old May 8, 2004
Ok, fixed it. It was a belt. The dumb one that's connected to the pulley. I got some Belt Dressing and sprayed that on. No more squeak.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
CurryBomb
May 8, 2015 10:16 AM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
