Strange brake grinding condition
Old Mar 17, 2004
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
About 6 month ago i had to replace my oem brake pads because i could hear the noise indicator. So i made the mistake of replacing them with some cheap pads. Everything went fine for the first week and i also used the brakes very gently for the first 300 miles so as to break them in. After two weeks it started to make noise and was grinding and groaning like hell everytime i press on the pedal.
Now i'm experiencing something very strange. When i apply the brakes firmly at low speed, it makes a splashing noise. It's like liquid splashing/boiling at the front end of the car.
I also noticed that my brake discs are not as smooth as when i was using my oem pads. they have circular grooves on them.
Any idea what it could be and how to cure it?
Old Mar 17, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
You may want to replace those cheap pads, cuz it seems like all of your problems started after you put them on. You should do it as soon as possible to avoid further damage to your rotors.
As for that splashing sound, I have no idea what that could be.
Old Mar 17, 2004
Da1lyDr1ver's Avatar
maybe you should use ceramic pads if you dont have them in already. you might have semi-metallic pads in which are a little harder in compound and are also louder.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
old97civic
Jul 9, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
Grey
17
Feb 21, 2004 06:21 PM
TonnyHegger
Feb 11, 2002 10:51 AM
