A/C Question
Old Aug 11, 2004
botmark's Avatar
botmark is an unknown quantity at this point
A/C Question
I have an '02 EX Civic (Canadian Model). The a/c this summer doesn't seem to blow as cold as previous years.
When I drive on the highway with the a/c engaged, the air temperature fluctuates. The Honda dealership says this is normal. I went for a ride with a service advisor and he stuck a digital temperature gauge stuck into the centre vent. The temp. varied between 39 deg F and 48 deg F. He said the a/c was working fine and that the compressor cycles off if the air gets too cold.
My concern is:
1) Isn't the temperature cycling also a sign of low refrigerant?, and
2) I don't feel the compressor kicking on & off as I drive.
Does anybody else notice this kind of behaviour with their a/c?
Old Aug 11, 2004
It's basically normal. The compressor will kick on and off all the time, so the air won't be refrigerated constantly. A common problem is the system losing charge a little, but that's different. If you want colder stuff, switch to envirosafe.
To test your problems, drive on the freeway at a constant 65mpg for 30mins and then see how cold it gets. That will allow the lubrication fluids to circulate. You can also get a voltmeter and watch it closely. When the compressor turns on, it should drop a few volts.
Old Aug 11, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
If you have a dark interior, it will take a little longer to cool off given that it was baking under the sun.
cukaracha
30
Jul 26, 2015 12:01 PM
cukaracha
Jul 23, 2015 08:50 AM
Jul 14, 2015 03:39 PM
beeemerdude
Jul 10, 2015 09:22 PM
ZILLA
Jul 5, 2015 05:24 PM
