RSX seats install help needed...
Old Oct 18, 2004
bradaven760's Avatar
bradaven760 is an unknown quantity at this point
I am buying some RSX front seats. Wanted to know how they are mounted. Is it as simple as just 123 or do i need to buy some brackets or somthing. Just wondering. Can some one help me out?
Brad
Old Oct 18, 2004
Da1lyDr1ver's Avatar
if the seats come with the brackets then its as simple as 1-2. for 3 you're gonna have to enlarge a hole in the seat bracket so the bolt can screw into the threads. of the 4 bolts on the brackets from the seats, 3 bolt right up, and like i said about the 4th, it needs to be modded. not hard but you need a dremel tool.
Old Oct 18, 2004
ImPulse's Avatar
I installed mine last night within an hour...
There are black plastic "caps" covering the rear 2 bolts (they pop off)
then, take the bolts out
unplug the wires
take the seat out
put new seat in
plug wire
bolt in the seats
WAS A BITCH FOR ME, I really had to use my muscles but, I ended up getting it to fit
I only put 3 bolts in... The seat is fine
Old Oct 18, 2004
wonderz's Avatar
wonderz is on a distinguished road
so do we need oem brackets from RSX to get the rsx seats in?
Old Oct 18, 2004
ImPulse's Avatar
the rsx seats should come with brackets... Just use the rsx brackets
Old Oct 18, 2004
Thanks...
Well guys thanks for the help... A couple PM's were sent.. Please check and get back to me. Thanks again!
Brad
Old Oct 18, 2004
chrisleecool's Avatar
unplug the wires
take the seat out
put new seat in
plug wire
bolt in the seats
dayum Jay, you found the seats!???
how much? where'd u find'em???
dayum I want them bad now..lol
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
ballmich
Jul 9, 2015 11:59 AM
fvckbg
Jul 7, 2015 07:08 PM
