Sqeeky Clutch
Old Sep 11, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
Sqeeky Clutch
My car has started to make the infamous sqeeky clutch sound. I have 10,000 kms on my car (Not miles). Is there anything I can do about it?? Does it really affect anything or is it just an annoying sound??
Thanks, Phu.
Old Sep 11, 2004
2K1Civic17"Gabe's Avatar
Could be a master cylinder. Mine went after about 60-65,000 miles though. I would ask Honda or somebody if you are under warranty, as long as they dont charge you just to listen to the noise. I replaced mine for like 200 including labor (parts ordered from Honda). I think mine could have been more of a click though.
Old Sep 12, 2004
phuviano's Avatar
bad master cylinder?? huh?? I thought this sqeeky clutch pedal problem was common in our 7thgens. I heard people talk about it b4. I didn't really think the sqeeky clutch problem would actually happen after 10k though.
Anybody else have any input???
Old Sep 12, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
I had that problem.....It's one of the bushings under the pedal....if you take it to honda they will oil up that bushing for you and it won't squeak anymore...but then after a few days it dries again and you have ot take it back....I just ignore the sound now...maybe later i'll take it in to replace the complete pedal I dont' know...but thats what your problem is
Old Sep 12, 2004
LazyDog01's Avatar
Raceway Park Track Tech.
Yea my car does the same thing, all it is a spring that dries up from time to time. If you do alot of stop and go traffic in heat this will happen more quickly.
Old Sep 13, 2004
phuviano's Avatar
so there's nothing really wrong with the car though, correct?? I don't mind the sound that much. I usually don't hear cause I got the music going. I usually hear it at night cause it much more quiet outside, and I usally don't play the music as loud at night.
Old Sep 13, 2004
NaSh123's Avatar
ya nothing is wrong...you can take it to honda if you want just to be on safe side but from what your describing nothing is really wrong....there have been other threads about this if you want you can search and see whats going on
Old Sep 13, 2004
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
def. going bad..sorry to say my friends clutch started squeaking and it was a gonner..
Old Sep 13, 2004
NaSh123's Avatar
what you mean breeze?
Old Oct 31, 2004
CrazyCanuck's Avatar
CrazyCanuck is an unknown quantity at this point
I have the same problem with my 2003.
I had the "creak" on my clutch pedal. Turned out he master cylinder was gone (after 30000 kms). The new one lasted 10000, it's back in getting replaced again.
Old Oct 31, 2004
Revmaster's Avatar
Revmaster is an unknown quantity at this point
That happened to me. Honda only places some grease on the clutch and it was gone. After over a year it was back again and I placed some grease again myself.
Old Oct 31, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Theres nothing wrong with the clutch. Yes it is annoying, I agree but its normal. I had the same noise on my 93 civic and I currently have the same noise on my 01. Its just one of those honda things. :\
Old Oct 31, 2004
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
my 02 ex is sqeekin as well could one of you name the points where i should apply grease
Old Nov 1, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Don't listen to those who say your clutch is gone. This is a very common problem in all Honda's, not just ours. It's just a squeak, nothing more. A good lubing will get rid of it, but it does need to be lubed regularly (like once or twice a year) if you want to keep it squeak free.
I've had my clutch squeak since 8,000 miles 3 years ago and I didn't bother with addressing it back then. And now 3 years later at 60,000 miles, it's still that same squeak, no better, no worse... and I still don't bother with it. And the clutch still feels great.
Old Nov 2, 2004
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
okay my car had the squeak and clicking clutch and the problem is not inside of the car its outside of the car. Under the hood right where the header is there is a littler rubber boot which houses the linkage which the master cylinder puts pressure on. Its that joint that is making the noise not your pedal. So I would take it to the dealership and have them lube that joint with some lithium grease and the noise should go away for a long long long time. This is a very common problem with hondas.
Old Nov 2, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
^ya thats where its coming from, i have the same noise
Old Nov 2, 2004
EM2Civic's Avatar
EM2Civic is an unknown quantity at this point
My DIY of the clutch fix, works for me
linky
Old Nov 2, 2004
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
ya I had that same noise too. Come to find out it was my master cylinder and they replaced it for free under warranty.
Old Nov 2, 2004
I never said your clutch is gone by the way, the master cylinder is different. It costs like 175 for a new one, and it WILL fix the squeek, as long as your clutch isnt slipping, your clutch is fine. Your clutch is bad when your rpms are higher than they should be, like your engine sound really loud, and you arent going very fast, or it should be lower RPM's.
Old Nov 2, 2004
the prob with the master cylinder is that it isnt getting enough lube, so lubeing it would be a temp fix, but getting a new master cylinder will fix the prob for a lot longer. Mine went at like 70,000 miles, but was quiet before that.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
