Rear tailights don't work
Old Oct 2, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Hey guys this is weird I just noriced it tonight. Neitehr my parking nor tail lights work in the rear. Front is fine, brake lights are fine. I doubt it's the bulbs since all (4?) are out. Where I can check if the fuse burned? or any ideas solutions or procedures to diagnose?
Old Oct 2, 2004
Fuses first. Then you can try other things. If only brake lights were out, I would say it's the switch. But now prolly just a fuse.
Old Oct 2, 2004
winnerpl's Avatar
Ok as it turns out the front parking light doesn't work either. Do it must be the parking light fuse. What label is under, is it "Day Light"? Wanna make sure. Thanks guys
Old Oct 2, 2004
pmau's Avatar
pmau is an unknown quantity at this point
It's called the 'small light' fuse in your engine bay. If you installed anything new lately (ie. radio, alarm, indiglo gauges), check the wiring.
Old Oct 2, 2004
Civic04's Avatar
Civic04 is an unknown quantity at this point
^^ yep happens alot. Mine did it after i instaled my hu and missed the extra illumination wire.
Old Oct 2, 2004
winnerpl's Avatar
bah thanks guys turns out it was that, and now I also burned the spare one too (bah!). It's def wiring in tthe relay of my neon kit where it's connected to the parking light. Gonna check that out in the morning. I can get these small spare fusues at autozone or strauss right?
Old Oct 3, 2004
winnerpl's Avatar
hmm nm i replaced the fuse but it still keeps on burning. I totally disconnected my neon kit but still no go. Any ideas would be appreciated guys.
Old Oct 3, 2004
pmau's Avatar
Not sure how neon's work, but if you 'tapped' into other wires on your honda wire harness, check if it burnt the wire.
Old Oct 3, 2004
winnerpl's Avatar
well i did tap into it but through a relay. Plus I thjink the fuse would go out first before a wire burned. :/
so lost
roverben
Jan 21, 2019 05:16 PM
pheaton
May 4, 2015 08:26 PM
ORskier
May 3, 2015 12:54 PM
leon1
Apr 28, 2015 07:32 PM
Thees1
Apr 14, 2015 08:23 AM
