03 Ex Tranny 3rd Gear Grinds! Help?
Old Sep 30, 2004
V2Civic03's Avatar
V2Civic03 is an unknown quantity at this point
Whats up. Im new to this board. I joined this week. I have a 2003 civic ex, with a V2 AEM intake, DC Sport Headers, TYC Tail Lights, 18" Konig Flatlines. Ill get a pic soon. But right now im having a problem with my tranny. Whenever i go to shift into 3rd gear at high rpms it grinds. unless i push the clutch all the way in then wait about 30 seconds then shift very slowly. If you got any suggestions or info let me know! Id appreciate it. Thanks
Old Sep 30, 2004
Gecko's Avatar
you'd have better luck getting an answer in vehicle issues forum
Old Sep 30, 2004
Havok2k1's Avatar
Wicked Pissah Admin
moved....
Old Sep 30, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
it's a problem with every tranny ever. 3rd gear is the most grinded gear out of any gear, imo.
busted syncro
Old Sep 30, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Try changing to Redline MTL. Honda will blame any and all mods you did to your car for the problem. Many people have had good success with Redline MTL.
Old Sep 30, 2004
scatman's Avatar
Still in the game...
when i had my 01 ex i had the neuspeed short shift adapter and thats the only time i would ever grind into third gear...even tho it happened only a few times. i think you may not be putting the clutch in far enough. try focusing on putting the clutch in more when ur winding ur motor up high. in my si, i have to concentrate on throwing the clutch all the way in while goin into second when shifting hard cause of the way honda made those trannys ( almost all of them grind when shifting hard into second gear). they're **** transmissions
Old Oct 1, 2004
V2Civic03's Avatar
yea thanks for all the suggestions. its been happening for a while and im def im pushing the clutch in all the way. i know some technicians that work for honda
and im prolly gonna have one of them look at it. one said im most likely looking at a
whole new 3rd gear and sychro. but the worst of it all is i wont have my car for about a week. how much am i looking at if i want to get a new aftermarket tranny?
Old Oct 1, 2004
nindoo's Avatar
Why is my vagina bleeding?
On upshifts, what happens if you clutch in put the car in neutral and then clutch out. then clutch in then shift to third?
On down shifting have you tried rev matching before shifting along with double declutching.
Old Oct 1, 2004
V2Civic03's Avatar
ill try that once i get off work, ill let you know. WORK SUCKS!
Old Oct 4, 2004
V2Civic03's Avatar
Tried it! Still grinds going into 3rd at high rpm! Any other suggestions? Befor I take it to the service department.
Old Oct 4, 2004
sw388integra's Avatar
new tranny time....
Old Oct 4, 2004
nindoo's Avatar
I'm no expert but I'm guessing you damaged your gear. When did it happen? If you shift in lower RPMS does it change fine? I've accidently grinded my gears a few times in high rpms, I guess I need to be careful as well.
Old Oct 5, 2004
V2Civic03's Avatar
Nah, it shifts fine in low rpm, im gonna take it in next week to get it fixed. I cant wait to have a good feeling tranny again. It started happening about 3 months ago. I just took it easy and tried not to grind it as much. Thanks for all the suggestions you guys kick
Old Oct 5, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
My 03 ex always grinds when I shift into 3rd at 2nd gear redline. It has always done this. It will always do this. I try not to redline 2nd unless I have to.
Old Oct 8, 2004
exturbo6's Avatar
yeah 3rd gear for me too on my 04..
Kcpowerhouse
Aug 25, 2015 01:15 PM
JetsterDajet
Aug 15, 2015 08:07 AM
beeemerdude
Jul 23, 2015 03:53 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
