Bad Reception w/heater
Old Aug 12, 2004
y.0. KiLLa's Avatar
Powered by Honda
well...after all..i finally discovered a problem with my civic....okay so yesterday night while driving home i accidently hit the heater while trying to put the ac on..i was listening to the radio and when the heater went on my radio made stacticky noise..so i just shut it off and the radio worked fine..so im like wtf..i put it back on and again the "st" starts blinking and the reception is all staticky..i dunno what the prob is..i just got my tints but i dunt think thats it cuz the radio works fine...ne1 have this prob..lol i doubt it..
Old Aug 12, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
What kind of tint did you put on?
Old Aug 12, 2004
y.0. KiLLa's Avatar
Powered by Honda
i got 20% tints..i dunno..when im listening to the radio and i put the rear defroster on it makes static..when i shut it off its fine..
Old Aug 12, 2004
bradfordtheguy's Avatar
bradfordtheguy is an unknown quantity at this point
if you notice next time you look at your car, there's no antenna, anywhere....that's because they integrated it into the rear window. all the lines you see back there have 2 purposes, one as an antenna, and two as defroster. it's prolly just some electric noise being picked up by the antenna...i'm sure someone will explain the exact reason, but i'm sure there's absolutely nothing wrong with your car.
Old Aug 13, 2004
Search around the site. Many people who put on tint experienced some problem with the radio. And you may have been added to the statistic!
Old Aug 13, 2004
I really doubt the heater would cause static unless you have a faulty ground someplace. It's probably the tint blocking the radio signal.
Old Aug 15, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
mine does it when you put the Vent button i think its the vent button the one all the way to the left on the bottom row of lil buttons..had the car over a year thats the first time i noticed it about 4 nights ago i was astonished
Old Aug 15, 2004
habs_hater's Avatar
habs_hater is an unknown quantity at this point
whoever put your tint on screwed up becuase they broke one of the antenna grid lines. Easiest way to find the break is to put a piece of cardboard on the outside of the rear glass, then with a piece of steel wool rolled into a point, slowly go across the antenna grid from one side to the other. Make sure the rear defroster is on. When you go across the open in the grid with the steel wool, you will see sparks. then take it to a glass repair shop or a dealer to have them repair the grid
Old Aug 15, 2004
y.0. KiLLa's Avatar
Powered by Honda
okay will my defroster still work? i dunt mind it making noise cuz i never use it and i always use a cd player..so it rlly dunt matter.
Old Aug 15, 2004
The defroster may cause problems to the tint over time, since it does heat up a bit.
Old Aug 17, 2004
518's Avatar
518
518 is on a distinguished road
I dont have any problems after tinting my window (Quantum Film) and its not even dark. However, I find it very hard to listen to AM stations on my aftermarket HU. I guess aftermarket HU isnt meant to be tuned at AM stations
Old Aug 17, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i had this same exact problem on my old 97 eclipse gsx. rear defroster on, radio reception sucked. turn it off and its crystal clear. the antenna wasnt built into the rear window, i had an automatic mast style. no tints on the car either. i dont know what the problem was, just saying there could be a correlation (sp?) between the two and it might not be the tints
Old Aug 18, 2004
y.0. KiLLa's Avatar
Powered by Honda
well thank u all for ur input..b4 i got the tints the rear defroster worked flawlessly with the radio..but after tints itdidnt..i doesnt matter i think..i never use the defroster lol...n i always listen to the cd player..but yea i also kinda noticed that sometimes the radio stations have a lil static...but o0 well..im not gunna bother bringing it back..
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
