Car Heating bad head gasket?
Old Jul 7, 2015
Bounddyy's Avatar
Bounddyy is an unknown quantity at this point
So I have 1999 LX which recently started to heat up. Its started with a radiator/cap leak and then thermostat. Both of these were replaced it still started to heat up but started to build a lot of presurre to the point my pipes would fly off. When starting the car with the radiator cap off the coolant would flow out like a fountain (symptom of bad gasket releasing air/gases into the coolant) I've even replaced the water pump at this point but now I have the head open and I see no signs of a bad gasket.
Except the gasket is split FYI I'm no expert. So any help would do look at the attached photos for a better POV.
See the photos.
[IMG][/IMG]
Old Jul 8, 2015
Re: Car Heating bad head gasket?
Carry the cylinder head into a machine shop and have it checked for warpage.
Old Jul 8, 2015
Bounddyy's Avatar
Will do seems to be tho ahh man.
Old Jul 8, 2015
Warpage max limit spec is usually 0.002" (0.05 mm), you can't eyeball that.
For comparison, an average sheet of plain white paper just measured 0.004".
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
BREADFAN
Apr 15, 2015 08:58 AM
deus-ex
Apr 13, 2015 12:29 PM
