Err, where is this oil comming from and why?
Old Oct 24, 2004
ponyman's Avatar
ponyman is on a distinguished road
So I have noticed lately that I have what looks like a very very small oil leak comming from in the area around the dip stick. I'm not sure if it is comming from the seal on the dipstick, or if it is comming from the valve cover bold that sits right there, but there is definitely a little leakage going on. I'm running 0-20 Mobil 1 Synth oil, I'm wondering is it too thin, or what? Is anyone else having this issue???
Old Oct 25, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Which dip stick are you talking about? Oil or Trans? If it's Oil dip stick, then I suggest you look around the drain plug and oil filter. Make sure they are tight. Filter should be 3/4 turn hand-tight. The drain plug should have a crush washer but not required.
Last but not least, check the oil dipstick for correct oil level. It should not go over high.
Old Oct 25, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Check to make sure that the breather isn't clogged up, and the O ring on the dipstick is in place.
Old Oct 25, 2004
dariusld's Avatar
dariusld is an unknown quantity at this point
What does the drain plug and oil filter have to with oil around his dipstick
MIne has oil in the same spot, but the previous owner took it jiffy lube all the time so I don't know. I would think its the valve cover, because of the bolt right next to the dipstick. But why would such a new car(mine) leak from there?
Old Oct 31, 2004
ponyman's Avatar
^^^^Exactly what I was thinking, other than I'm thinking that maybe the dipstick o-ring is letting the oil pass. I'm also wondering if the 0-20 Mobil 1 is too thin and that is what is letting it pass through?
Xuhme
21
Aug 7, 2023 03:40 PM
BootyDo
May 7, 2015 04:46 PM
CivicVoz
Apr 16, 2015 08:07 PM
Unleaded
Jun 26, 2007 09:25 PM
civiccowboy
Nov 19, 2001 03:44 PM
