brake squeaking noise
my brakes now squeak whenever i let off the brake. it doesnt happen when i hit the brake and its not that the brakes are worn because i dont hear the safety pin, but it only happens once i stop or hit the brake and i let off that it squeaks whats the deal?
does it eventually go away? Like squeek for a little bit and then stop? I had a problem with my taurus sho that sounds like your problem. My brake caliper was actually seizing up. It would stick when I put my brakes on just enough to rub for a while. Then they would release until the next stop. I had to end up replacing one of my calipers. Maybe?
mine do that too. When I let off the brake, I hear a squeaking noise from the rear. I wouldnt worry about it. I had it on my last car and this car and there isnt any problems with my brakes. Brakes are noisy. Just to be on the safe side, check all 4 brakes and see if there is a problem, otherwise you are ok.
when the brake pads are installed, it is a good idea to apply some brake grease/compound to the metal shim between the pad and the caliper, it prevents the squeaks at slow speed braking and reverse braking, its like $1.50 for a little packet at the parts store. that may be the problem.
it only squeaks when i let off the break, its not a continous squeak. its just hold brake down like when at a stop light and then green light let go of break and squeak, thats it, but you can hear it clearly and i find it kinda of embarrassing.
how many miles? maybe your seals are shot, or maybe you need to bleed your lines. I personally would check pad wear, the clip that sqeaks when your pads are thinning only makes noise when you are off the brakes, it stops when you are on the brakes..
are you talking about that safety pin we have that lets us know when our pads are running thin, that constant noise it makes? well its not that. its just a squeak not a continous squeak. its like if you sit on a old couch and when you get up the couch squeaks but stops once your off it. miles are running at 35,000. would this trigger my check engine light? it has recently turned on but have no clue what is wrong with it and honda isnt checking it till next week?
Originally Posted by SkipBarber
wtf...what cylinders? rear drum brakes are composed of drums and shoes...
