secondary o2 sensor
Old Nov 13, 2005
Smokeman909's Avatar
Smokeman909 is an unknown quantity at this point
secondary o2 sensor
HI, I have install a megan racing catalyctic converter.
I tried to use an O2 simulator but I think it does not work.
My question is how is the engine reactine to a missing secondary o2 sensor or to my originial o2 sensor pluged in other than telling me that there is a problem with my 3way catalyctic converter?
Since there is still the 1rst o2 sensor that checks the air/fuel ratio.. can the 2nd o2 sensor still mess up the engine with the air/fuel ratio?
Since it is starting to get cold here and the winter is coming I am thinking of just putting my original cat and maybee experiment next summer.
thanks for any hints
Simon
Old Nov 13, 2005
nope the second sensor has no function in engine operation. only the first one determines a/f and ecu feedback. just find a mil eliminator that works. members here have em. its only important because if something else on your car goes wrong, you won't notice (since the cel light is already on).
Old Nov 13, 2005
What is mil eliminator stands for?
Is it different than an O2 simulator?
Old Nov 13, 2005
its malfunction (engine light) eliminator. it tells the ecu everything is okay with the cat.
Old Nov 13, 2005
Diablo's Avatar
Diablo is an unknown quantity at this point
make sure the wires are connected like the instructions say. you did get instructions with it right? i got mine from this person on ebay http://cgi.ebay.com/ebaymotors/O2-Ox...spagenameZWDVW it worked good no problems what so ever. just icase yours doesnt work
Old Nov 13, 2005
I wired it correctly, I found out the groud, heater groud, signal, etc.. it just does not seem to work.
Mine does not look like the one on ebay. It looks like a yellowish plastic cube with 3 wires coming out. It was suppose to flash when working properly but it does not.
anyway I order one from ebay for 12 that looks like the one ine the link
Old Nov 23, 2005
kennysime's Avatar
kennysime is an unknown quantity at this point
i put on the megan high flow cat on my 2004 civic si and the next day i had a check engin light which was the Catalyst System Efficiency Below Threshold crap. not sure what to do now.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
h4ldol
Apr 24, 2017 08:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
familyguy
Engine Swaps
Nov 26, 2012 02:59 PM
puertorro
Dec 7, 2007 05:28 PM
