Need Help!! Removing alternato
Old Nov 10, 2005
avngrboy's Avatar
avngrboy is an unknown quantity at this point
I am going to remove my alternator because it is making a knockin niose and wanted to see if anybody had any tips on how to remove it?
Old Nov 11, 2005
Michalo187's Avatar
Abortion Survivor
Its pretty much straight forward. Take off your front driver side tire if you want it to be super easy. The I usually take off the ps pump for more clearance then the alternator has a bolt on the top which is a 14mm then on the bottom it has a tensioner bolt that needs to be taken off which is 12mm and then its off. Good luck
Damn HeadGasket
Aug 23, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
