Need help... weird pinging sound
Old Oct 25, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Every time that I accel. I hear a high pitched ping. What's weird though is that depending on how hard I press the accel. pedal, the tone of the sound changes. I can actually damn near create a song by accelerating. At this point I'm thinking it's got to be something having to do with my accel, but I have no idea what. Sorry if this has already been discussed, I tried searching, but what exactly do I search under for my problem???
Old Nov 9, 2005
chriz eryk's Avatar
chriz eryk is an unknown quantity at this point
i got the same problem here.....have u got urs sorted out yet ?? Any advise ?? Thanks !!!
Old Nov 9, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
pinging, hmm?
does it kinda sound like a bunch of pennies in a can being shaken up?
perhaps you may have some bent valves? ... have you ever mis-shifted?
Old Nov 9, 2005
TheSmuggler's Avatar
Pinging is because there is something wrong with your engine. You better get that checked ASAP or you might blow it entirley.
Old Nov 9, 2005
Jrfish007's Avatar
yeah, that's not a good thing, get that checked out ASAP.
Possible causes could be bad bearing, pre-ignition, bent valves, many many other things too. I would get that looked at. Just remember that it may cst less to replace your engine than fix it in some cases.
Old Nov 9, 2005
chriz eryk's Avatar
thanks guyz for ur feedback.....
just went to honda service center and checked....they said its a normal sound. tested another civic 1.7 and kinda (kinda means maybe my ears has gotten accustomed to the sound) actually hear the sound as well.
but still not too satisfied bout it. hope there is nuthin wrong. the sound is
actually like putting a small pebble in a coke aluminium can and shaking it. u can only hear when u open the window and the surrounding is quiet or in an enclosed area like a parking lot.
any advise from u guys.....izit normal. its killin me!!!
Old Nov 9, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
well...in all honesty..if your definition is lacking, you might have a bad wheel bearing, wouldn't sound like a pinging perse, but it'd have a mechanical sound, or even a grind....when you accelerate do you feel anything in the pedal? if you get a constant tap-like feeling like a tap that feels almost like the speed of the wheel revolutions, that's most likely what it is....
Old Nov 9, 2005
chriz eryk's Avatar
nope nuthin from the pedal. i am quite sure the sound is coming from the engine bay area. oh ya according to the service center, the sound is probably the injectors sound. izit possible ??? the weird sound only comes
when the car is moving though......
ugh....headache
Old Nov 9, 2005
CraigW's Avatar
Simple test is run the fuel low and then put in .25 to .5 tank of premium gas and see if the noise goes away.
Old Nov 9, 2005
Jrfish007's Avatar
That will help if the noise is preignition.
Honda uses a fairly hard material for the valve seal, and it is normal to hear a slight sound from this. I would say you can hear it with the window down and the radio off, it will be a slight tick. Nothing to worry about, but if you can hear with the windows up and the radio on, then you have a probelm.
Old Nov 9, 2005
check your spark plugs. that sound is not normal. but it seems like you're describing alternator whine where the tone gets higher as the rpm goes up. if you hear the sound metal makes when it hits, then there's a problem.
Old Nov 9, 2005
causes of detonation
-lean a/f
-low octane fuel
-improper ignition timing
-carbon deposits
-excessive head milling (hi compression)
causes of preignition
-plug too hot of a heat range
-plug not tight enough
-detonation
-excessive valve guide clearance/improper seal
-overheating
Other problems occur when the plug gap is wrong, anything that raises the temperature like advancing ignition timing, raising compression, platinum plugs run hotter than copper, etc.
Old Nov 9, 2005
chriz eryk's Avatar
errr.....for mine the tone did not get higher as the rpm goes up. it just stays the same and sometimes the engine sound will drown the weird sound.
the service guy says the injector sound might be escapin from the open area near the fender as per pic below. (darn...can't post any pic until i reach 15 post. any other way ?? )
well i am still not entirely convinced but am hoping dat it is normal......
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
1khilari
Jul 9, 2015 08:12 PM
