stripped nut
stripped nut
As I was attempting to install my new header, I stripped the nut
that is on the far right as you are looking at the header. The one that is kinda hard to get to. Any ideas or suggestions on how to get the darn thing off? Please help!!
that is on the far right as you are looking at the header. The one that is kinda hard to get to. Any ideas or suggestions on how to get the darn thing off? Please help!! Take off the p/s pump and you can get to it easy. It can try a lot of things and how did you strip it by tightening or losening? You were probably using the wrong socket its a 12 mm is that what you used?
I'd rather not go through the trouble of taking anything off. I did use a 12mm socket, i guess i was just at a wrong angle or something but it stripped. And my dumb*ss didn't stop before it was too late. The nut is pretty round now. Oh, btw, I was trying to loosen the nut to put in a new header.
Well just take it to a mechanic and he will get it off for you. Just tell him your new to mechanics and you messed up. You most likely did have it in the wrong angle its a pretty tuff one for a beginner. Good luck
I went to sears and got craftsman bolt-out damaged bolt/nut remover, http://www.sears.com/sr/javasr/produ...%26+Diesworked like a charm. Awesome product. I just need to get a new nut now. thanks for your guys' comments.
PC Tech / Autocrosser
Yeah, those things work great so long as you can get to the damaged nut. If you are trying to get on the back side of a WRX's down pipe with one, then you're screwed.
Dam that actually works i had never heard of it maybe i will need to invest in one since my mechanic fvcked up one of my power steering bolts to the tensioner and now its very difficult to get the belt off. How much was it i can't find the price
that cratsman bolt out kit was one of my first tools that i bought and man i've used it soo many times its a life saver it should be a must have for any local garage mechanic
h4ldol
Electronics
28
Aug 25, 2019 07:04 PM
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
stank
Sep 16, 2015 07:40 AM
