Clutch Squeak!
Proudly Canadian
Clutch Squeak!
So this past spring I noticed squeaking whenever I pressed in my clutch, and when I was releasing the clutch it would squeak too. You could feel it in your foot too, like it was rough. Anyway, Honda replaced the master cylinder and some other crap in that clutch assembly, and all was well. This was done in June 05.
Well now, it's squeaking again. I brought it back, I said WTF you just replaced these parts.. so they said this time it's probably the Slave Cylinder. So today they replaced that. Does this make any sense here? I mean, the master cylinder is attached to the pedal, and when u press it down, I can see how that's the part that is squeaking. Why would it be the Slave?
Drawing of assembly:
The master cyinder is #5, the Slave cylinder is #7
where exactly can you here it squeaking from? from what you say it sounds like it is coming from the clutch pedal and may just need some white lithium grease up in there.
Honda tends to just throw parts at the car untill its fixed.
Proudly Canadian
My car is like 1 year old, it's not that. I read thru this already. I asked them to lubricate they said it's already lubricated, there's no need.. the parts come lubricated from Honda
Proudly Canadian
bah. I'm just telling you what they said. I said "cant you guys lube up the master cylinder with lithium grease?" and they said no we used a stethescope to locate the problem to the slave cylinder. The parts come pre lubed so we dont lube them again. It was the same tech who replaced my master cylinder in the summertime... if it keeps squeaking, well then obviously I'm gonna spaz out and say LUBE IT YOU **** SMOKERS. Im not disregarding anything, just passing on the info they told me.
they also replaced some DOT fluid or whatever? not sure what that is, but they said sometimes that gets contaminated and dries out the seals and whatnot..
When you said clutch squeek that you could feel in your pedal, I didn't need a stethoscope to tell you it was the slave cylinder. Trust me, the lube in the slave cylinder can last years or months. Just follow the DIY next time and save the trip to the dealership.
As for the DOT fluid, it is the clutch fluid (which is brake fluid). They probably flushed the fluid after changing the slave cylinder.
Proudly Canadian
Squeaking again.
Called the service manager, he said this is a reacurring problem in many civics, and he said sometimes it will take 3-4 master cylinders before it's fixed. GG Honda Quality.
Proudly Canadian
Clutch is squeaking again as you may have heard.. Well I went to the dealer, and I showed them that article about lubing up the cylinder etc etc.. It ends up it's not either of the cylinders. It's the pressure plate. He jacked up my car, sprayed lube on the pressure plate, noise GONE. They have to drop my tranny out this Friday to replace the plate
Proudly Canadian
Originally Posted by dariusld
It sounds like you don't know what your talking about.
Downed but not for good
man i wonder how much they would try and charge me if i went to those *** clowns and told THEM what to do. maybe they wont charge me since I made thier dumb asses break open the transmission to stop another noise (which ofcourse started up again days after they fixed it) about three months ago.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Klame9420
Sep 7, 2015 10:03 PM
