squeaking at rear suspension
Re: squeaking at rear suspension
i have a squeak too, mine is coming from the rear drivers side camber kit. probably because they are so old, i just spray some white lithium grease whenever it squeaks and it stops it for about a week. i should just replaced the part i know
It squeaks even at smooth road.
The mechanic advised:
- to replace both rear shocks assembly because one shock has leak (moist on the upper portion)
- to replace lower swing arms bushings
- to replace both lateral link assembly
- Can leaking shock can cause squeaking sound?
- Is the lateral link also known as camber kit?
Check out this bulletin and see if it might be your issue:
http://workshop-manuals.com/honda/civic_dx_sedan/l4-1668cc_1.7l_sohc_mfi/steering_and_suspension/suspension/control_arm/control_arm_bushing/component_information/technical_service_bulletins/all_technical_service_bulletins_for_control_arm_bu shing/02-070/sep/03/suspension_rear_suspension_squeaking_noises/
If you can find a real copy of Hondas Civic bulletin 02-070 it has pictures and stuff.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
