2003 Civic EX Vtec - speedometer and tach bouncing
Old Sep 14, 2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
This may have been the only car we could find in a hurry, when we needed to, but it sure has a few problems.
Lately, the speedometer and tach needles have started bouncing up and down occasionally. I'll be doing 40 and suddenly the speedometer starts bouncing all over the place, like up to 80 MPH and down again. Then it goes back to working fine.
Old Sep 14, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: 2003 Civic EX Vtec - speedometer and tach bouncing
Run instrument cluster diagnostic procedure With the car off and the keys in the ignition, 1. Push and hold the trip-reset button 2. Turn the lighting switch on 3. Turn the ignition switch on within 5 seconds 4. Turn the lighting switch off, then on, then off again. 5. Within 5 seconds, release the trip/reset button, then push and release it 4 times repeatedly. This will run a self-contained diagnostic procedure that will sweep all the gauges from stop to stop. They should stop at 0 at the end of the cycle. To repeat, simply press the rest button again. It will stay in this mode until you turn off the ignition. This procedure is very useful for checking for burnt bulbs (as all bulbs flash in a steady rythym) and checking needle operation, as all needles slowly sweep through their full arcs. I also use it when reinstalling needles in the cluster, as the cluster returns the posts to electronic zero, then it's a simple matter of putting the needles at zero and carefully pushing them on.
Old Sep 14, 2015
See if someone forgot to fully tighten the alternator bolts.
Old Sep 14, 2015
I have some other checking to do on this car, too. When I flip the high beams on, the headlights go out. Not sure if the high beam filaments are burned out, but I'm gonna replace them with brighter ones anyway, and will see. Just gotta get past all the obstructions. I have a video.
Old Sep 14, 2015
Aww jeez. You STILL haven't fixed this yet?
Old Sep 14, 2015
Nope. Super busy - running a home based business and taking care of a handicapped sister, injured in a car accident. Plus, I had to wait for the new super bright bulbs to come from Amazon.
Plus, I tend to avoid things a little, that I haven't done before. Then I do them and realize how easy they were.
Old Sep 15, 2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
Those are pretty damn good excuses. When I don't do something it's because I lost interest in it or I am just plain lazy.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
