anyone know how to check the timing belt or should i take it in?
Old Nov 7, 2005
thorough's Avatar
thorough is an unknown quantity at this point
just asking since I have heard that thats one vital thing you should have checked on your civic. I have had some trouble locating my owners manual althought i dont remember it saying much about it. FYI its a 2001 LX coupe.
ok found the DIY on changing it on Similar threads. Still want to check it prior to 110,000 miles just to be safe.
EZ-thx in advance
Old Nov 7, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
just have it changed at 90 k along with your water pump or your motor will die. literally.
Old Nov 7, 2005
ya i just had mine done at 44k but they were swapping the cam gear. i would do it 90k for sure and also get water pump, crank pulley, and both seals.
Old Nov 7, 2005
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
i have an 01 ex with 92k miles .. so water pump , timing, crank pulley and valve cover gasket and head gasket?
btw can i just replace the crank pulley with an underdrive kit?
im NEW to Honda so i dont know alot ... sorry for the noob question ... lol i know the cavalier tho ... lol i had a few ...
Old Nov 7, 2005
MajinB's Avatar
don't get a under drive crank pulley cause it will screw up your car. the gaskets is a personal choice. my dad didn't change his and he has a 95 with 220k miles on it. no leaks. so wait it recommended is water pump and timing belt
Old Nov 7, 2005
no gaskets. they don't pull the head off or the valve cover. you need the cam and crank seals. get a stock crank pulley cause they tend to break around 60k miles. Also, this would be a good time to throw on an adjustable cam gear for later even if you don't think you'll need it. cause you'll have everything off anyway. here's my aem.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
