here is a question if anyone can help....
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
i bought this 96 dx in february this year with 84000 miles, one owner, nice shape, clean interior ans so on.....
ever since then i have been sticking to the 3000mile mark on oil changes but not to the tranny fluid.... ( its an auto btw ) ever since saturday the tranny engaged the gears really smooth... saturday i decided to change the tranny fluid along with the oil to get it ready for winter. i got it done at jiffy lube and what they did was drain the fluid and add some more... NOW when i put the car in drive and the car shifts to second gear the change is so hard that the car feels like it gon go ahead and leave me behind. it kinda feels like someone bumping me in the back.. but the tranny is not slipping and thats why im puzzled... i know its not a 7thgen but the tranny is basically the same set up as the 7thgen auto tranny... u know P - R - N - D4 - D3 - 2
BTW the car 93000 miles now
could it be the fluid f@cking up my tranny???
any info is greatly apreciated
Old Nov 13, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
hmmmmmm never have jiffy lube work on your cars. did they use the pump or just unplug and refill. cuz if they use that pump it can mess up the torque converter. it just forces all the bad fluid through it and itll get clogged up. i did that to my 91 accord and after i flushed it it shifted funny. it is best to never change it after a certain point just make sure the level is good.
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
nah i dont think so... he said he was just gon drain it and put new stuff in
here is the recipt that eplains what they did....
Old Nov 13, 2005
yeah they just drained and filled but older honda trans are tempermental about that stuff. make sure the level is good, most of the time they dont know what they are doing.
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
other that that should i contact them... i had aamco in mind to ask them questions on why is the tranny doing this
Old Nov 13, 2005
yeah talkto aamco and see if they can tell you if it is something jiffy lube did wrong (i.e. wrong fluid, not enough or too much fluid) but other than that they arent resposible.
Old Nov 13, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
you can do that yourself, just take the dipstick and and check if the level is correct. also hondas use honda atf tranny fluid, dont use anything else unless you want to spend more money on additives. anyways, honda never had a good history of building the best auto trannies. last gen accord/tl/oddessey was the worst, but in general, alot of older Hondas have trannies that kick or make weird noises due to poor or the lack of tranny service. honda requires a lot more servicing than other cars in the tranny dept.
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
interesting
Old Nov 13, 2005
honda tranny fluid only. now its gonna have to be drain/refilled a few times to get the other junk out that they put in.
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
thats what i was thinking
Old Nov 13, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
ok i think this is a simple misunderstanding. you paid them to changed your tranny fluid, not flush the whole system out and put new in. so what im saying is, go get a whole system flush. maybe that will help.
here is another thing- my friend had his tranny fluid flushed completey. and when they put the new fluid in, they discovered leaks in the system cause the fluid dried up in the cracks and filled the hole lol. so maybe it was too old to change. idk. good luck
Old Nov 13, 2005
heres a tip never go to jiffy lube again. and dont get the flush they ruin your system.
his trans seal was probably alright but those system flushes put pressure on your trasnmission and that is why it started leaking. jiffy lube is a schiesty company i know cuz i worked there. you have 2 people who know what they are doing the rest are just idiots. i was inthe group of the people who knew how to work on cars.
Old Nov 13, 2005
yeah flush is a bad idea. even honda says no to that. just drain and refill
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
im taking it to honda tomorrow
Old Nov 13, 2005
MajinB's Avatar
just make sure that they flush the whole effin system not just what jiffy lube did. and go to jiffy lube and let them drive it and tell them to fix it. they have to
Old Nov 13, 2005
actually jiffy lube doesnt have to fix it. they have soooo many loop holes. when you sign the work order you just sold your soul, by signing you agree to the service and if it does cause immediate severe problems like it locks up they are at fault but once you drive off your liable for it. basically you are not taking your vehicle to a certified car tech. it is hard to explain their legal mumbo jumbo. but if you hassle them enough they might refund you.
Old Nov 13, 2005
PICHY's Avatar
ALGARETE
they used
penzoil multi-veh atf 55 gal
thats what the receipt says
Old Nov 13, 2005
MajinB's Avatar
i don't think thats the right fluid...they have to use the right stuff to not be liable...
EDIT- that paper says 3000k miles warranty. your havin probs like 20 miles in... go bust there asses!
Old Nov 14, 2005
PICHY's Avatar
ALGARETE
i talked with management overthere and they said that what the newb did was wrong.. he drained some out and filled it with some more creating air in the lines.... he told me if its not gone by friday to bring it back and he will compleatly drain and flush the tranny and put some new fluid in????
if he does that i rather go get the honda ATF and have them put it in how much is that **** anyone know??????? $100 worth for a flush and refill???
Old Nov 15, 2005
savedadogs's Avatar
savedadogs is an unknown quantity at this point
Creaking Sound When Turning Left
Hi, I have a 2004 Civic Ex Coupe. It has about 7,000 miles on it. Recently, I noticed that when I make a left turn sometimes a creaking sound occurs...it sounds like it is coming somewhere around the front of the driver's side door (near the side mirror). The noise sounds like something is being stressed. Anyone heard of this before? The noise just suddenly appeared about a month ago...I does not always happen.
Sorry, Moderator can you please transfer this to a new post? The advanced edit is not working for me. Thank you.
Old Nov 16, 2005
DDragon7's Avatar
You should be still under warrenty, bring it back to Honda.
robjcivic
Mar 12, 2017 12:10 PM
LilNic13
Nov 28, 2015 10:26 AM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
