Anyone here done a o2 sensor yet?
Did a little searching, mostly found o2 sims.
I'm throwing codes on and off for PO133 slow sensor response bank 1 sensor 1. Has anyone here done one have a good place to buy, prices, diy?
Thanks, wanna do this as soon as possible seeing as it's my primary sensor.
01" EX
01" EX
01" EX
01" EX
Originally Posted by tacheon
I've done them on a few other vehicles. Get yourself an oxygen sensor socket. It's basically a deep socket with a notch in the side to allow the harness to go through it. You can buy an oxygen sensor from anywhere which sells car parts along with the socket. It's as easy as changing a spark plug. Just unplug harness, and remove the oxygen sensor. Installation is same as removal. If it doesn't turn with a moderate amount of force, use a penetrating lubricant, wait an hour, and try again. Forcing it out will result in a stripped threads.
Thanks guys, good advise. Anyone esle have info on it. I can't believe more people on here havent done them yet, there many cars on here with 100,000 m + on them!
part number 18 40.00 bux plus shipping oem honda. a proper sized wrench will work fine do not use an adjustable. If you have problems getting it off run the car around the block and try it while its hot.
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
yea its fairly easy to get off. me and my friend used wd-40 to get it off and it didnt strip cause we got it bak on easily. my secondary o2 is given the same thing as yours. gettin it replaced soon
yeah, but don't use WD-40 when it's hot.
A SIM is fine for SECONDARY sensor, but not primary. I think that the car would run better with both, unless you have no cat.
The light is going on and off, few days on, few days off, what up with that?
My car was doing exactly what ur car is doing... then the light stayed on, and now im getting hit with an $800 CAN repair bill for various plugs and injectors and the like, as well as an O2 sensor.
im not sure if its stuff i could do myself or not... id love to do it tho.
This is why I love this forum.
Its an easy install. Yes get the socket and becareful not to strip the o2 nut.
You might be able to just remove the old o2 sensor and clean it off using a propane torch to burn off the crap that may have accumlated on it.
Good luck.
Originally Posted by igetmadchocha
never heard of it
Good luck.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
