2 problems
Old Oct 21, 2005
glunk's Avatar
glunk is an unknown quantity at this point
2 problems
1 low washer fluid light won't go out
2 when going around left hand turns rear brake drum rubs on backplate,
makes a nasty scraping sound.
thought it might be the bearing but just returned from a 600k run and no sign of bearing heating up
any ideas
Old Oct 21, 2005
streetglower's Avatar
1. have you checked to see if you are low on washer fluid?
2. pull the rear drums and check everything.
Check the easiest things first.
Old Oct 21, 2005
glunk's Avatar
washer is full
pulled both rear drums everything is tight
you can see where drum is rubbing on backplate
also when car is jacked up there is no slack in bearing
Old Oct 21, 2005
If the washer fluid is full and the light wont go off, you may have a bad switch.
Not sure about the drum issue though, do you have stock drums?
Old Oct 21, 2005
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
We have a low washer fluid light??? I've been totally empt and never seen any low washer fluid light
Old Oct 21, 2005
its only on the cars in canada.
Old Oct 22, 2005
glunk's Avatar
have i problem fixed, slight warp in left rear backplate
little tap with a hammer did the trick
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
