HELP: transmission fluid leaking
im a psychopath...what are you looking at?
i noticed a red fluid leaking and staining my drive way...i believe the red fluid is transmission fluid, i just want to know how i can fix this...i don't want to go the dealer if i don't have to...did anybody here had the same problem? how did ya'll fix it?
i have searched, but not found anything.....
oh yikes first i heard of that. it could be serious, of just a loose drainbolt. I would really take it in tho before it gets worse and ruins the tranny.
jack up the front of the car and see where its coming from. Like gearbox said, it could be a loose tranny drain bolt, or worse, a leaking tranny gasket. But before you do take it in to the dealer, check it out yourself and let us know the general area of where the leak is coming from.
mattdoc
Mar 14, 2017 12:10 PM
nefliminator
May 28, 2015 10:18 AM
