rebuild engine
Old Jan 16, 2006
ripspecv's Avatar
ripspecv is an unknown quantity at this point
rebuild engine
ok i need to rebuild my 01 civic engine and i was wondering where i go and how much to get all the parts to do it? i need all the bearings i guess and gaskets and im not sure what else thats why im asking here.
Old Jan 16, 2006
djmota's Avatar
it probably would be easier to find a good used low milage engine and just drop it in. d17's are a dime a dozen.
Old Jan 17, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
you my friend, can now swap to a k20a2.
Old Jan 17, 2006
ripspecv's Avatar
how much for a k20?
Old Jan 17, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
how much for a k20?
If you really think on race buy a K20A2.
K20A2 for some $2000-3000 or more, plus some other parts and a lot of work. If you just use your car as a dayly driving buy a low milage D17 for some $500-700, loose some bolts and wires, drop in the new engine and ready to go...
P.S.
If have the money, I will swap to K20A or K20A2 (K20Z...).
Old Jan 17, 2006
gmcuajo's Avatar
And if you want to rebuild your engine the better way is replace almost all removable parts: gaskets, oil seals, bearings (comes in color codes), water pump, timing belt and tensioner, oil pump, piston rings, valve seal and guides, freeze plugs, head studs, spark plugs, etc. And a lot of work have to be done...
And need a repair manual...
Buy a low milage engine.
Old Jan 17, 2006
PunkingCivic's Avatar
I need TP for my bunghole
between parts and labor to rebuild a d17, it isn't worth it in my opinion.
check ebay for used motors:
D17: http://motors.search.ebay.com/search...rclo=&saprchi=
K20: http://motors.search.ebay.com/search...rclo=&saprchi=
jbradley4809
Apr 7, 2017 04:23 AM
zack22490
Apr 29, 2015 03:17 PM
Uncle X
Apr 15, 2015 09:59 PM
supermex
South
106
Feb 8, 2002 06:57 AM
Cross
Jan 6, 2002 01:31 AM
