a video from me, to you guys with your slippin tranny
Rep Power: 0 a video from me, to you guys with your slippin tranny
http://video.google.com/videoplay?do...layable%3Atrue
yeah thats what mine is lookin like right now. feel free to use it. made it for those ppl that can't.
pay attention to the rpm after i turn left.....right at 3,500rpm going into 2nd gear.......then BOOM MODAFAKA
Rep Power: 428 I couldnt help to notice that your car is still COLD. That is normal when the tranny hasnt fully warmed up. Thats the first thing I noticed when I saw your video was your temp gauge was still on the "C" mark. Once the tranny fuid warms up, it will go back to normal.
Rep Power: 294 yeah that's true, but that much slip does seem kind of exsive to me. I guess the real question is does it do it when it is warmed.
Rep Power: 428 can you take a video of when the car is at normal operating temp. If it happens when warm, you may have a problem, but again, We only saw it when the vehicle was cold, so to me, everything looks normal.
Civic Gurlies
Rep Power: 292 Sorry cold or warm, it's still going. That's exactly what happened to mine. so I started letting it warm up. Failed anyway. Took it to Honda, one week later and two attempts on replacing it I finally have it back.
Rep Power: 787 agreed. the trans will try to stay in lower gear until the engine warms up kinda like its stuck in D3 but this is very cold like 0F how it gets here. did the tranny break yet or starting to...
Originally Posted by CivicSF
that is NOT normal for a bone cold auto trans. i can start it, get out the driveway in 10 seconds, stomp on it, and it'll hit great. the only thing that takes time to get up to speed is the shift times.. which is probably a combo of the engine and trans as well being cold. always shift a tiny bit slower when bone cold, but definitely no slippage like that. that's a bad trans buddy.
Go ahead and replace the transmission because even mine is an 02 civic lx auto and it shifts perfectly even cold or warm and I have 113,000 miles on my car. That is a huge slipppage
Rep Power: 0 im thinking of gettinga rebuildint kit, but then again....**** it?
its still moving from 0 to 80. thats all i need....when it goes then it goes....ill get a rebuilding kit then.
but does any1 kno exacly whats wrong with it? clutch? synros or w/e its called? bad gears? what is it!!!!!?????
Rep Power: 787 there is a defective part (clutch pack?) that will cause it to fail on its own even if you have an oil cooler. a rebuild kit is a must otherwise it will just break again. You maybe have another 1k miles before the trans just gives up. could be sooner or later too.
let the devil out
Rep Power: 363 ok ok ok with all the tranny threads, we all know the 01+ vics had issues so just go ahead and save yourself time and upgrade to better fluid such as red line or royal purple , and do the TCI master overhaul kit or 5 speed swap. Otherwise I hope its still under warranty.
Originally Posted by varner88
^^lol no hes been driving it like that for far more then over 1000,miles.
chris dont make me chop your useless **** off....and its like....over 5,000 miles LOL.. happen in june and its still going. its been well over 5,000 to be honest with you, i already did altest 2 oil changes on the motor since then.
ThE CoRRupToR
Rep Power: 322 Trust me you dont wanna have a tranny go out on you while youre driving like me. Cuz it really does suck!! I had to push it outta the way which isnt fun. My car right now wont goto any gears even reverse!!!!!!! And i hear a loud whinning noise coming from the tranny. Im gonna convert to sick.....
Rep Power: 787 he has an auto tranny and its not supposed to rev really high like that before switching gears. that means its slipping
Originally Posted by Spracto
i don't mean to be a total nub but what exactly is happening in that video that tells you his clutch is slipping?
Rep Power: 0 My '02 Civic EX started doing this around 100,000 to 110,000 miles when cold. Once it's warmed up it shifts better, but not as crisp as it used to. It used to be crisp cold and warm. Typically I start the car 15-20 mins before I leave for work between Sept through April because it's so cold in the morning.
I just turned 130,000 the other day and everything is the same, so long as it's warm it shifts fine. If I don't have time to let the car warm up, I shift it manually through the gears, take it up to 3-4k before shifting to quicken the shifts, just in case. Slippage is bad news and I was dissapointed in seeing this start happen.
Unfortunately I was negligent about changing the tranny fluid and did it's first change after I noticed this problem start, which like I said was over 100k miles. Mostly was delaying it thinking it needed a flush job from a shop, not a simple drain and refill which I could have done thousands of miles ago.
Anyway, I have noticed a loud whining noise recently when cold that changes with the RPM. I haven't checked it out yet but it's typically a bearing on an alternator or PS pump that causes that, which I'll be checking out this weekend. It goes away when warm.
My car is a bone stock commuter that gets about 3,000 miles a month. Unfortunate for the car it's not just freeway miles, I make about 120 miles a week worth of that, but the rest (200-300) is a 100 mile round trip on a twisty 2 lane highway that is constantly changing from 20 mph to 65+. Though thats still better than in-town wear and tear.
If the tranny goes it goes and I'll fix it. Though I'm starting to think a Toyota Camry should have been my choice since I was hoping to run over 200K before doing anything major. Knock on wood I might make and exceed that, we'll see.
Jordan
Jordan
