Civic 2002 diesel won't start
Old Jan 16, 2006
darkreign's Avatar
darkreign is an unknown quantity at this point
Car : 2002 Honda civic diesel
The car worked fine , till it got tranported our way, it just won't start!
Checked fuel level
Checked air in fuel
Checked fuel pressure (pump works)
Checked inhibitor (green key symbol goes out)
Checked emergency button (behind dashboardlocker)
Checked timing belt
Checked ECU/ECM codes : none found
It could be possible the diesel injectors are not operated , these are probably mass controled (since they are getting 12v) via the ECU/ECM , but I don't have PGMfi tester anymore (sold it a while back) so I can't measure pulses.
As final option we replaced camshaft position sensor, these are a common problem on the Mercedes and BMW diesels, it's a BOSCH sensor as well and these break down a lot (magnet) w/o giving a code. Needless to say this gave zero result. Worse case scenario ECM fried..
I did have the 7th gen workshopmanual on CD-rom (beeing a former Honda dealer) but it got lost
Anybody have a clue?
Old Jan 16, 2006
dalaw's Avatar
Bone Stock!
Wow I never knew a 7thgen civic diesel even existed. You from Europe?
Old Jan 17, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
There is no diesel Civic's, oh man, you messed up big time my friend!
Old Jan 17, 2006
brent_01civic_e's Avatar
brent_01civic_e is an unknown quantity at this point
http://www.honestjohn.co.uk/road_tests/?id=55
there is one lol
ENGINES/TRANSMISSIONS
1,686cc diesel: 99bhp (74kW) at 4,400rpm / 162 lb ft (220Nm) torque at 1,800rpm
Transmission: 5-speed manual only
Old Jan 20, 2006
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
WTF.......hmmm News to me
Old Jan 21, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
what the ***? civic's run on diesel? new news to me bro lol.....where did you find that car?
Old May 22, 2006
darkreign's Avatar
Mechanical problem solved, diesel injector return feed leakage, too low pressure to operate direct injection (<1200bar) , new injectore fitted
8th gen Civic has 2.2 CiTD engine with 140ps and 340nm torque 0-60mph in 8sec !!
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
