whats this called?
Old Jan 21, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
whats this called?
its that white thing.....it broke when i was taking my door panel off....im holding it with tape so i need a new one asap.....and where the fawk can i find it?
Old Jan 21, 2006
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Go to a salvage place or Honda......its like a little holder that holds the lock mechanism in place....I broke mine too....dont know what you would call it but I just described it to them and we figured it out together
Old Jan 21, 2006
spoonJDMlX's Avatar
ok now i gota problem....my door doesnt open........and i can only thing of one reason....
Old Jan 21, 2006
if you locked it...and now cant...its prolly cause your tape fell off
Old Jan 21, 2006
just leave the door panel off til you fix it so you can lock/unlock it.
Old Jan 21, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
So get in Dukes of Hazzard style
Old Jan 21, 2006
Rep point for you for the Dukes
Old Jan 22, 2006
spoonJDMlX's Avatar
how am i suppose to take my panel off when i cant open the door to take it off?
Old Jan 22, 2006
spoonJDMlX's Avatar
wooot! 100th post! gatta make something out of it.....anyway...so if i just change the white plastic **** with a new one from honda....it will be fine?
Old Jan 22, 2006
spoonJDMlX's Avatar
anyone?
Old Jan 22, 2006
manahoonie's Avatar
i would think so... did you have any luck getting your door to open?
Old Jan 22, 2006
Jap-Euro Fusion
Push the Keyless entry button or stick a key in the door. Thats just the lock/open indicator, its linked to the lock mechanism, which should still operate.
Old Jan 22, 2006
Ricky's Avatar
Ricky is an unknown quantity at this point
the door doesn't open because of that it needs to be pulled by the inside where the hanger looking when you took out the door panel just unlock the door but remote or manual bye driver side then go look for that metal piece that was connected to the handle in the car .. it might have fallen down in side the door panel if no work close your window up so you get access to the door machinism and play with it until open.. as for the white piece you just have to go back to honda and special order that piece...
Old Jan 23, 2006
spoonJDMlX's Avatar
alllight, well i found the problem. and it was very obvious, it had to do with that white plastic but that wasnt the problem.
i had the door panel on hanging, but it was hanging and not fully on. so that didnt let the handel fully come back. so i took the metalic peice off the handel and open it with my hand. so that worked.....now i just took the panel off and i'm going to see if honda has that white part that i need
sorry for the spelling and typos....came home from work at 8 and been ****ing around with the car till now. good night guys...thanks for all the help. seriously
Old Jan 25, 2006
spoonJDMlX's Avatar
well guys i ordered the part today at honda, dude told me they dont sell that so i have to get the whole lock cable...w/e its only 8.97 total. so yeah im going to be doing that tomarrow. does anyone know how to disconnect the cable?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
dlg1985
Jul 23, 2017 10:03 PM
Jrosa
Sep 14, 2015 08:24 PM
