clutch and steering wheel vibration issue
Old Jan 8, 2006
R3DL1N3's Avatar
Question clutch and steering wheel vibration issue
well my clutch is pretty much gone and ive got to have a new one. with that said, i got some tokico blues put on this weekend with some new tires. when the guy came back with the car it needed an alignment so i went to sears early today and got it done. when i got it back it felt pretty good until i was coming back on the interstate a little while ago. first through third isnt that bad. i guess thats around 65 mph max not trying to go fast. once you get to fourth and fifth at around 80 the steering wheel vibrates like hell but it still goes in a straight line. my real question is should i wait until i get a new clutch to see if the problem fixes itself or should i have it checked out asap and see if it could be another problem?
Old Jan 8, 2006
you need a wheel balance
Old Jan 8, 2006
R3DL1N3's Avatar
thanks
Old Jan 8, 2006
and please don't goto sam's club or some other retard place because they won't do anything and you'll still have the problem. goto an actual alignment/tire specialty shop that you know does good work.
Old Jan 12, 2006
specificcivic's Avatar
specificcivic is an unknown quantity at this point
agreed....your issue might also be that the tread depth on both of your front tires are different. It could also be caused by have 2 different tires on your front wheels period.
Old Jan 12, 2006
Buwisit's Avatar
balatuba
Buwisit is an unknown quantity at this point
i have the same problem my steering wheel vibrates whenever i got 60+ mph, it only occured when i installed hayame but i got wheel alignment, what maybe the problem?
Old Jan 12, 2006
wheel balance
Old Jan 12, 2006
Buwisit's Avatar
balatuba
any explanation why wheel balance? i just want to understand
Old Jan 12, 2006
RedBull's Avatar
RedBull is an unknown quantity at this point
I have the same problem right now... and i had my wheels balanced twice at two different places. The last one said i was good... but it took alot of weight on the front drivers side... my steering wheel seems to be canted alittle to the left now too. Went to another place and they said sometimes this happens with certain tires at certain speeds... i hope to get it checked again... but right now i got my money in a Vtec cylinder head and no Vacf II I thought it coulda been a bent wheel.. but they are only 6 months old.
Can this be any kinda alignment issue or something that gets over looked unlike a wheel balance? R3DL1N3 talked about his clutch... can a bad clutch do this too? Sorry if i sound lame... i'm still kinda new to all this.
Old Jan 12, 2006
alignment issues won't make the car vibrate at a certain speed.
Old Jan 13, 2006
Buwisit's Avatar
balatuba
but how can you say that wheel balance is the solution if redbull had his wheels balanced twice but still vibrate and i dont think that clutch is the problem coz mine is ok but still vibrates
Old Jan 13, 2006
i had my wheels balanced twice too but turns out they didn't know how to do it. i had to take it to a real shop before they said all the weight is gone and the other place did nothing so you never know. if the balance is perfect, and it still vibrates, something is either wrong with the rim (bent) or the tire (uneven wear). when i did have the balance done right, they said they also moved the two worse tires to the rear so i would feel it even less. its been fine since but i'm driving to chicago tomorrow unfortunately so when i get back i know it will be vibrating due to all the weights falling off. roads suck up there.
Old Jan 13, 2006
RedBull's Avatar
I just got my wheels balanced again today at Augusta Customs down here in Georgia... sorry for the shamless advertisement. They rebalanced all four of them... and said something about a "run out" which if i remember right... it's when they can't put any more weight on the wheel... but they got it close. They also moved that wheel to the back passanger side. I think it might be a issues with my tires, but they sat in my basement for a year while i was in Iraq, could be a bent wheel too... cause i hit alot of holes (going way to fast)
>>> Gearbox.... you ain't kidding about the roads in Chicago... was there last summer for a friends wedding. If you cananswer this if you get on here anytime soon... cause i dont' wanna bother Xproductions again... but once i do the vtec head swap, do i have to put on a EX (stock or aftermarket) header? Or will the DX one work for the time being?
Old Jan 13, 2006
it should work just fine as far as bolting up. the head mounts are the same i believe. remember the cat is in the header for dx/lx so replacing the header will remove the cat and you won't pass emissions if that matters to you.
Old Jan 13, 2006
RedBull's Avatar
THANKS ALOT! I think i have all my questions about the swap answered... except if it'll actually work when i'm done. I'm trying to find a Vafc 2 for under $250. Then i'm good to go.
Well down here in Georgia i don't have to worry about emissions... but i head back to Pennsylvania in April and i have worry about it there, hmmm... i'll search for a aftermarket one for the dx/lx so i can keep the cat.
BTW: i don't have the vibration issues... just the normal roughness of needing a new suspension. She lasted almost 5yrs though!
Old Jan 13, 2006
i just sold my vafcii for $210. but if the buyer doesn't send the money i'll let you know.
Old Jan 14, 2006
RedBull's Avatar
Thumbs up
For sure!!! Thanks
Old Jan 18, 2006
RedBull's Avatar
I did some reading and the manual i got says the steering wheel vibration can be caused by the following:
1. Tire or wheel out of balance or out of round
2. Loose or worn wheel bearings
3. Worn tie-rod ends
4. Worn balljoints
5. Excessive wheel runout
6. Blister or bump on tire
If this is correct... then people that have this issue could be caused by several things that do get over looked because everywhere i go they tell me it could only be wheel balance.
Old Jan 18, 2006
well thats because the most common cause of vibration is wheel balance or bad tires.
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
