hood rattle how to adjust?
Old Dec 16, 2005
kiwi133's Avatar
kiwi133 is an unknown quantity at this point
my hood rattles at just above idle, I assume there are some rubber bumpers that you can screw in and out to adjust how high the hood "seats" but I can't find them.
help it's annoying!
Old Dec 16, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
They are 2 black round rubber **** looking things at the front, left and right side.
Old Dec 17, 2005
Matty Civics's Avatar
Matty Civics is an unknown quantity at this point
I had this problem, it turned out the be the lever you use to open the hood
with.
Old Dec 17, 2005
kiwi133's Avatar
ok...so how did you fix it? are you talking about the safty/secondary latch lever (that you have to reach under the hood and pull up with your fingers), or some part of the linkage for the main latch release?
and I'll check those again tinman, thanks
Old Dec 18, 2005
just loosen the rubber stoppers on each side of the latch. it will make it close tighter. same goes for the trunk.
Old Dec 20, 2005
kiwi133's Avatar
yes, the rubber stoppers seem to have done the trick, thanks guys!
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Civic720
Sep 10, 2015 10:06 AM
fvckbg
Sep 8, 2015 09:55 PM
First Car
Sep 8, 2015 08:54 PM
dantheman42
Sep 4, 2015 01:10 PM
