exhaust gasket question
Old Dec 19, 2005
D5cIvIc's Avatar
i have an EVO2 exhaust is its leaking where the midpipe and the axel back is connected. I bought a brand new greddy gasket and on one side it's completely FLAT and the other side is kind of angled out a bit. My question is that does the gasket need to be placed on the exhaust a certain way or anythign to prevent leakage? like does the flat part of the gasket have to face a certain side? basically is there a wrong way to put on a gasket. thanks for all your help guys.
Old Dec 20, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
You should be able to use both sides of the gasket, I have that same problem on my Evo2 but I looked at it and noticed that the flange on my exhaust was sort of curved and caused it to leak
Old Dec 21, 2005
D5cIvIc's Avatar
i had this muffler shop just bolt it up and the leakage stop for the moment, but sometime it still LEAKS very very very little on the bottom of the flange. Enough where i can see the gasket getting wet at one little spot. this is frustrating...
Old Jan 25, 2006
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
I have the exact same problem. Just tightened it up today, but still leaks. Any solutions? My gasket, I found, is broken towards the bottom side, so I turned it so that the broken part is on top, yet still a problem.
Old Jan 25, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
is it a donut gasket or a flat paper-ish gasket?
Old Jan 25, 2006
Glad you asked, Derek, cause I took a pic of it when I inspected it.
Old Jan 26, 2006
D5cIvIc's Avatar
yeah, i even bought the GREDDY exhaust gasket for freaking 12 bucks ( waste of money) and my exhaust jsut started to leak again at the same dam spot. I just think its the exhaust shop that doen'st put it on right. I'll try to buy another one later and put it on myself again and this time i'll use a breaker bar to tighten the bolts.
Old Jan 26, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, the flat paper-ish gasket.
it should hold up just fine ... I don't know why you guys are getting a leak ... is the leak pretty bad?
andy, you could get a gasket like that at pep boys ... just bring your old one in and compare it to the ones they have, it should be fine ...
if you're still having trouble, let me know and I'll take a look at it
Old Jan 26, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
liquid leaks? fp60 in the gas will fix that hehe
Old Jan 26, 2006
I'm getting an air leak, and some water goes through, too.
Thanks derek, I'll try to fix it and we'll see. I really don't think the pipes are warped, but it could be the case.
I don't have a torque wrench, but I tightened it as much as I possibly could. Could that be the reason, that the bolts aren't torqued down?
Old Jan 27, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nah ... torque wrench won't matter for that. But yeah, tighten as much as you can ... I hope you're not using the honda spring bolts on it ...
Old Jan 27, 2006
Spring bolts? On the axleback? I just have the bolts that we used when we put it on together.
Old Jan 27, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, nevermind then. they -should- be okay ... again, unless the flanges are un-even, then stuff will leak out.
get a new gasket ;P
Old Jan 27, 2006
Yep, that's the plan now. I just couldn't make it last night to Pep Boys before they closed.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
EK_Eddy
Jun 6, 2015 07:31 PM
mrohitredd
May 28, 2015 10:03 AM
hokiedad4
Apr 30, 2015 07:18 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 8, 2001 12:14 AM
