Air Leaks
Old Dec 15, 2004
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
Air Leaks
I have a 2k1 Civic with like 145,000 miles on it and i have some crazy air leaks with the drivers and passenger side doors. Is there anything i can do to stop the leaks? None of the rubber seal looks worn out. What should i do? Honda wants 155 bux a door to fix it and its all labor no parts involved... so what sould i do?
Old Dec 16, 2004
lilravingmatt's Avatar
lilravingmatt has a little shameless behaviour in the past
i have the same problem with my civic 01 ex
trying rescrewing the brackets more tighter and try 2 move it more forward.
the brackets is #17 in this link:
http://www.hondaautomotiveparts.com/...gry5=DOOR+LOCK
Old Dec 16, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Several ways to fix air leaks:
Option #1. dollar bill, masking tape and several minutes of your time:
Rolldown your front windows. Slip the dollar bill between the door. Hold on to the bill from both ends and slide the dollar bill back and forth until you feel an area that is "soft". Once you find it, put a masking tape to mark the position and continue to look for soft area. Go back to your masking tape, slip some paper or cloth under the door moldings to help push up the seal against each other.
Option #2. Another way of locating an air leak is to use a steam blower. I find it useful if you have a steam cleaning machine. Same procedure as Option #1 above. Rolldown the windows. Point the steam between the moldings until you see steam come out from the other end. Then mark the location and continue. Go back to your masking tape, slip some paper or cloth under the door moldings to help push up the seal against each other.
Old Dec 16, 2004
88d15HB's Avatar
88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted
check ur weather lining
Old Dec 16, 2004
88d15HB's Avatar
can i get a ma b
Old Dec 17, 2004
streetglower's Avatar
turn your radio up so you dont hear them anymore. Most of the new civics have this problem, it isnt a big deal.
Old Dec 17, 2004
haha, its hella annoying.. im going to try the two methods above and post results...
Old Dec 17, 2004
Toca's Avatar
Toca is an unknown quantity at this point
Thats what I do.. It worked for me
lilrob1213
37
Jun 29, 2015 06:45 PM
jbander
Jun 4, 2015 05:56 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
mievil
Apr 28, 2015 11:02 PM
