Im getting some horrible gas mileage....
Old Nov 17, 2004
yeehaw's Avatar
yeehaw is an unknown quantity at this point
I dont really get on it.
I use to get 360 miles on 12 gallons....
My last tank I didnt break 300.....wtf gives?
Its all highway and i cruise at about 75-80.....
Are my tires deflating, is soeone siffoning gas, does my oil need changed or what?
Im gonna want my old mustang back at this rate
Old Nov 17, 2004
streetglower's Avatar
go outside and check your tires, when was the last time you changed your oil, is your air filter dirty? only you will know the answer to that. Do some mainanence. Sounds like you dont do any just by asking if your oil needs to be changed.
Old Nov 17, 2004
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
air filter, tires, spark plugs
Old Nov 17, 2004
low04's Avatar
low04 is an unknown quantity at this point
yeah i am having the same problem only has 7000 miles on it but i havent had a tank last over 270 since the summer when i went to heat wave and then i got like 325-350 a tank so i know what you are talking about
Old Nov 17, 2004
yeehaw's Avatar
I bought the car honda certified 3 months ago.
Dont they change the plugs and clean the airfilter?
Also, Ive only put 3000 miles on the car since Ive had it.
The dealership said to change the oil every 5000 miles.
2 questions, what PSI do I put in stockers and would a K and N filter be worth it?
Old Nov 17, 2004
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
i wanna say its about 45psi. it will say on the side wall of the tires. probably in parenthesis and may be hard to read. it will probably be close to the edge of your rim.
Old Nov 17, 2004
think thats a little high, open the drivers door and on the jam there will be a sticker that will say what it should be.
Old Nov 17, 2004
jyoung's Avatar
jyoung is an unknown quantity at this point
well i would think as the oil is used longer your going to get some kind of loss in fuel milage relative to the condition of the oil, but that alone wouldn't make you lose that much gas mileage. if your driving inconsistently (maybe on that tank you shifted at an average of 3700rpms instead of 3200) this would also cause more gas to be used because of driving more aggressively. from the time i got my car off the lot to... it's first maintenance visit to honda (in 2 weeks) I've noticed the gas mileage has gone down. I also attribute it to me moving and now having to go through 50 damn stop lights goto work.
Old Nov 17, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
The door jam recommends 30/30 I think. The tire psi is only for installing. I run 34/32 usually, as it is better to be a few over than a few under. As for the gas mileage thing, even though its asked almost daliy , don't sweat it. I average about 26-28. I don't believe EPA estimates include drive thrus, warm ups, a heavy right foot, stickier wider tires, etc.
deanaZoom
35
Sep 19, 2015 12:22 PM
slammed925
Sep 13, 2015 11:27 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
