Car randomly won't start sometimes
Old Nov 10, 2004
DieselDrummer's Avatar
DieselDrummer is on a distinguished road
About 5 times in the past 2 years and 3 times in the past 4 months I will go to start my car after already driving it someplace that day, and it will crank but the engine won't start. I usually just have to wait a while and try again and it will work. It never does that on the first run of the day and it has mainly done it on days that were humid. Does anyone know the cause of this bc I took it in to get that looked at, and the diagnostic tests came back ok, and they couldn't recreate the problem so they didn't do anything.
Old Nov 10, 2004
SLO REX's Avatar
250+ awhp Stage 2
I have had the same problem, so I bought remote start for my 5 speed. What you have to do is take the key all the way out and put it back in and it starts up perfectly.
Old Nov 10, 2004
ncirom2003's Avatar
........... i wouldnt think the key would make the engine not ignite... but w/e
Old Nov 10, 2004
SLO REX's Avatar
250+ awhp Stage 2
I don't know why but that is what I did everytime and it worked every time. Very weird.
Old Nov 11, 2004
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
Have them check the starter..
Old Nov 11, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
The immobilizer does that sometimes. Yes, the key has to be far enough away from the transponder ring so it can reset. That's why you have to completely remove the key to try again. A pain, if you are planning a fast getaway
Old Nov 11, 2004
that makes sense bc the imobilizer shuts off fuel injection, so that makes sense that it would crank and not start bc it was getting no fuel. Is there anythay that can be done to fix it?
Old Nov 11, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
disassemble the immobilizer. problem solved.
Old Nov 12, 2004
tinman's Avatar
Try your other key, and pay attention if the green "KEY" flashes in the cluster when it won't start. If it flashes, It didn't read the microchip in the key. I found that if I was in a rush and stuck the key in and turned it right away, the Immobilizer did not have enough time to read the key yet. So now I give it 2 or 3 seconds before I start the car. So far it has worked right every time.
If your problem continues, you may need to replace the unit.
Old Nov 13, 2004
yea i tried to briefly recreate it by putting the key in really fast and starting it twice, and it didn't happen. I will have to keep trying everytime i drive to see if that is truley the problem, and know that i know what it most likely is, that green light will come in handy, too bad I never thought to look at it before.
Old Dec 6, 2004
civic2004byatch's Avatar
civic2004byatch is an unknown quantity at this point
My Two cents for this problem. I discovered that I had this same problem after I got a remote start added to my car and they added a module to remember the transponder code. I find that with Remote start the car works fine, No problem at all. but sometimes when I start with the key it just cranks. If i put the key in and wait 1 to 2 seconds before i crank then it starts fine, if i crank right away it just keeps cranking and wont start until i pull the key out and put it in again. Maybe for some reason it reads two codes? one from the module that was added and then another from the key? or for some reason the chip in the key is not getting fully charged at times that it does not start (because if you go through your honda owners manual it says the key charges when you put the key in your ignition.). Whos knows. but it is Annoying no matter what the cause.
Old Feb 22, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
ok, i've noticed this problem too and it usually happens if the car has already been driven; then on the return trip, the engine wont start right away.
it happened to me twice this week and both times i was already sitting in the car with the key in the "on" position for more than 10minutes. both times i had the cd player on but i dont have an amp or sub. i dont think it is the fuel pressure or the immobilizer because both times the key was already in the 'ON' position for a very long time.
the tempurature outside was already pretty warm for winter. around 10degrees celsius and clear sunny skies.
Old Mar 2, 2017
papa59's Avatar
papa59 is an unknown quantity at this point
Red face Re: Car randomly won't start sometimes
I have a 2003 Honda civic ex. Auto trans. 1.7. It does not seemed to be getting any fuel. I don't know why but it will not start. I don't know what an immobilizer is or where it can be found. The fuel pump comes on or makes the noise like its coming on when I turn the key . I am at my mind's end here and need some assistance . Any help appreciated!bradleyholland8@gmail.com
mistermenphis22
Apr 3, 2016 08:06 AM
rcolosi
Apr 29, 2015 07:48 PM
Blaster30
Apr 22, 2015 12:21 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
